Trick performance hardware sizes?
Old Feb 15, 2015 | 03:11 PM
Jake75's Avatar
Size:  147.0 KB which boats am I taking off
Old Feb 15, 2015 | 06:25 PM
TrickTurbo's Avatar
Truck Sponsor
The 6 on the turbine side.
Remove the bottom ones first.
Then while removing the last two on top.
Hold the turbo and slide forward.
Nothing will fall out. You will hear the inside shield clank cause its loose. But will not fall out.
You will also need to take you oil lines off prior to removing turbo.
Old Feb 15, 2015 | 09:06 PM
Jake75's Avatar
Sorry trying to make sure I get it right down wanna screw up the turbo. I'm removing the bolts numbers 1 correct? Name:  2015-02-15%2021.04.25.jpg
Old Feb 15, 2015 | 09:18 PM
TrickTurbo's Avatar
Truck Sponsor
Looks correct. The 6 bolt going rearward that screw into the turbine housing.
Old Feb 15, 2015 | 09:29 PM
Jake75's Avatar
got it im going to work on finding the leak tomorrow.
5.3lSilverado
25
Aug 29, 2016 12:48 AM
Silveradorst07
Dec 31, 2015 12:04 AM
maxspeed05V
Aug 12, 2015 06:29 PM
FlowmasterMufflers
Jul 30, 2015 05:03 PM
jrplz
Jul 9, 2015 12:07 AM
