trick kit ordered!
Old Jul 2, 2014 | 03:43 PM
  #21
Jake75's Avatar
tracking has the kit delivered! i will post pics when i get home! Thank you rick!
Old Jul 7, 2014 | 06:40 PM
  #22
Jake75's Avatar
Got the intercooler installed today...little more time consuming than I thought but all in all went well. I had to cut the crossbar under the hood latch to get a good fit. I also relocated my trans cooler to behind the intercooler(would not fit in front with 4" ic). I also had to cut about 4 plastic mounting tabs off the grill so the grill would go back on properly. The Dremel sure came in handy today!
Old Jul 7, 2014 | 06:42 PM
  #23
oakley6575's Avatar
Lets see some pics
Old Jul 7, 2014 | 07:09 PM
  #24
Jake75's Avatar
Got the intercooler installed today...little more time consuming than I thought but all in all went well. I had to cut the crossbar under the hood latch to get a good fit. I also relocated my trans cooler to behind the intercooler (would not fit on front 4" ic). I had to cut about 4 plastic mounting tabs off the grill so the grill would go back on properly without damaging the ic. The dremel got a lot of good use today! I also mocked up the cold piping everything looked good. Got a appt set with the tuner for the 17th so turbo will be on by then!
Old Jul 7, 2014 | 10:10 PM
  #25
Jake75's Avatar
Old Jul 7, 2014 | 11:22 PM
  #26
Choda's Avatar
Did u get the cast manifold?
Old Jul 8, 2014 | 08:02 AM
  #27
Jake75's Avatar
Yes I got the cast manifold
Old Jul 8, 2014 | 10:40 AM
  #28
jgb454ss's Avatar
U can't go wrong with the trick kit..u are going to lobe boost
Old Jul 10, 2014 | 07:29 PM
  #29
Jake75's Avatar
got the downpipe wrapped i will start the install of hot side monday when i get off work. planning on putting the springs for ~7 psi in the wastegate and using a manual boost controller to get ~10 psi for daily use. Thoughts? I also ordered a snow performance methanol kit. When should i start injecting meth i was thinking around 6psi
Old Aug 12, 2014 | 09:13 PM
  #30
Jetn3's Avatar
How's your build coming along? Any updates? I'm really wondering how your current cam, 226/230 113, is working out on your crew cab/turbo combo.
