trick kit ordered!
Old Jun 18, 2014 | 09:10 AM
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by Jake75
sounds good thanks i will look into the meth today. I called and left a message with you about upgrading to the 4" IC not sure if you recieved that message.
as far as boost control goes whats the best way to control boost? spring pressure or elecronic boost controller? I was thinking about getting an electronic boost gauge along with a electronic A/F gauge
Yea all is good.
I try to Check prior to shipping that paper work and what's wanted match up.
Controlling boost depends on your final goals.
If you want to play with up down etc then sure.
If you want X and that's it no need.
Air/fuel gauge
Boost gauge
Are must for safety and diagnosis if a problem pops up.
Old Jun 18, 2014 | 10:08 AM
Jake75's Avatar
Originally Posted by Choda
This will help
https://www.performancetrucks.net/fo...s-pics-521152/
You will 100% need injectors for anything close to 600 wheel. I have black ops 60 lbers and they are doing fine for my power level. You might need bigger ones.
If you are going to constantly be changing the tune/boost then an electronic boost controller would be best, if you are setting it to a specific hp or PSI then a manual hallman would be best.
awesome thanks for that link!
Originally Posted by TrickPerformanceProducts
Yea all is good.
Air/fuel gauge
Boost gauge
i guess seeing as i do not know how to tune i suppose a manual controller will be best. I look foward to hearing from you!
Old Jun 19, 2014 | 05:53 PM
Jake75's Avatar
i ordered a vacumm block today to hopefully keep things a little cleaner
Old Jun 24, 2014 | 03:05 PM
Jake75's Avatar
today i recieved my wideband and boost guages along with my pillar pod. does anyone know where i can get some paint to properly match the tanish color of the 2012 gmc pillar?
ALSO! Rick called and my kit is complete and will be on its way soon!
Still need- Meth injection, Fuel injectors, Fuel pump? (currently flex fuel)
Old Jun 26, 2014 | 09:33 PM
Choda's Avatar
I would recommend that u do not use a boost controller at first. Put the 4 or 6 psi spring in the gate and hook up the vac line. Keep it simple for first start up and tune.
Same for fuel / meth. Get the kit installed and making power. Once your ripping. Then add injectors and meth. It's not like it's going to cost you more money and time not doing them now.
Old Jun 26, 2014 | 10:21 PM
Jake75's Avatar
i didnt end up getting the boost controller i just went with the boost gauge and im going to run spring pressure...im kinda stuck between running 93 or e85. i wanna say that i have read when you run e85 you dont really need meth. then again i dont wanna go on a road trip and be limited to e85 since not many on the road places carry it. my goal hp is between 700-800
Old Jun 26, 2014 | 10:33 PM
Choda's Avatar
Remember that e85 flex truck uses a lot more fuel than 93. My flex truck was fine at 8 psi on stock flex pump and injectors. Not sure if they would have supported that much needed flow w e85.
Old Jun 28, 2014 | 01:19 PM
Jake75's Avatar
As of right now that's the route imma go since e85 isn't as readily available here. I'm still trying to decide what to do about the trans (6l80e)
On the other hand tomorrow I leave back home and start waiting for my kit to arrive!
Old Jun 28, 2014 | 02:50 PM
oakley6575's Avatar
If you make the jump to E85 you'll love it. But there is a lot to it. Its not a 'go fill up with E85 and run your heart out' type of thing. You'd need a stout fuel system to keep up with the demand. I'm on E85 and it is some amazing stuff. I will never go back to pump gas but there are 10 or so stations around Las Vegas who carry corn.
Old Jun 28, 2014 | 06:46 PM
Jake75's Avatar
Lol I'm in vegas right now!
