Trailblazer SS now with 2.9 whipple
Old Nov 26, 2014 | 10:38 AM
  #111
supermaro's Avatar
Nice, how much boost are you seeing?
14-15lbs
Originally Posted by BigKID
I would be interested to see a log file of the above dyno run. How much and what concentration of meth are you spraying?
I have the logs but too retarded to post them. IATs started at 100* ended at 118* Running Alky kit on boost reference(need to switch to MAF). 100%meth and 10/5 nozzles for a total of 15.
This is hardly apples to apples... this is a built motor with ported heads spinning the **** out of the blower. You have a stock 5.3, no?
So that means you don't want a 2.9?
Old Nov 26, 2014 | 10:58 AM
  #112
Vortec350ss's Avatar
You know I do... I want anything that will step my game up. I'm in a far different position than he is if I move away from the 1900.
Old Nov 26, 2014 | 11:41 AM
  #113
03sierraslt's Avatar
Cool, 416ci right?
Old Nov 26, 2014 | 02:32 PM
  #114
ZO6Ted's Avatar
Why don't you have one yet?
Just bought the truck 3 weeks ago. With recovering from cancer since April just really getting back in the saddle so it will likely be Summertime. Glad to be here at all lol. Hope its not later than Summer just depends on what I can produce. No question I do love the TVS as well. If there was a 2300 kit it would be a close call for sure.
True. However these newer model 5.3s it appears move a lot more air than the LS's so since it is offered why not? Besides, it gives me room to grow a little more without the expense of an 8 rib. Also what if I kill this motor like I did my last 2 (tuners). I would be going 6.2 as the replacement. Just thinking ahead. In no way am I degrading the TVS guys, just like the Whipple a bit better. It's also interesting Chevrolet used them on the COPO Camaros so...
Old Nov 26, 2014 | 03:18 PM
  #115
Your 5.3 won't need a large compressor with its high compression.
Old Nov 26, 2014 | 05:13 PM
  #116
ZO6Ted's Avatar
As supplied the 1900 puts out 6 psi and 105 hp increase over stock to the Whips 7.5-8 psi and 155 hp over stock with no pulley changes if you can believe the manufacturers dyno #'s. It appears to be a jackshaft design as well. Also when New Era did their 2012 Whipple 2.3 build he pointed out that the Whipple had an IAT advantage over other brands. So for the same money which would you choose looking down the road? I realize the 5.3 doesn't "need" a bigger slower turning compressor but it gives me more options doesn't it? I value your opinion and other blower guys here, since all I've ever had is an STS or Nitrous. Thought I might do something different this time although I still have the STS if the money tree doesn't bloom. Thanks!
Old Nov 26, 2014 | 06:02 PM
  #117
BigKID's Avatar
Very nice IAT's. Do you have any runs with the same setup sans meth to make an apples to apples IAT comparison? Any other cooling mods such as larger heat exchanger, pump, etc?
Old Nov 26, 2014 | 07:37 PM
  #118
supermaro's Avatar
Whipple it. Don't let the Maggie mob change your mind.
Do you mean do I have any runs with same mods and without meth?
I did do some cooling changes that did help out. But even before the meth and the mods IATs didn't get above 140s. But outside temps were hotter back then also.
Old Dec 14, 2014 | 07:46 PM
  #119
supermaro's Avatar
Old Dec 14, 2014 | 07:51 PM
  #120
Nice, great times!
