time for a new turbo help Mr decide..
Old Nov 21, 2012 | 11:56 AM
  #31
foose04's Avatar
Bump, where is the pictures of this bad boy?
Old Nov 22, 2012 | 03:29 AM
  #32
billetproof97''s Avatar
Bump again. You guys are making crazy power with the 4.8's makes me want to change my whole build plan
Old Nov 22, 2012 | 09:32 AM
  #33
Jake99's Avatar
The day I was going to order this turbo I ended up going with something different, IM all about trying new hopefully better things, my brother and a buddy of mine both got s475 now so I thought id try out a new turbo that came out the day I was going to order it. It's a turbonetics turbo, it uses the same 78mm compressor wheel as the hurricane turbo but have a slightly larger cover to flow more air, then on the hot side it has a split flange t4 1.15ar housing but have a 75mm (small side) turbine wheel that they use in some of there y2k turbos. This dude is rated at 1100hp , the turbo is almost identical to the precision 76-75 turbo I just got the 78, this one is also a ball bearing unit and is a direct swap cause it still had the 4in inlet 2.5 out on the cold side and a 3in out on the ex. There list price is 1400 on these and I picked it up for 1100. Should be the first to try this turbo out, pretty excided about it!
Old Nov 22, 2012 | 09:39 AM
  #34
Jake99's Avatar
And I haven't got it yet, I'll post up pics as soon as I get it.
Old Nov 23, 2012 | 04:26 AM
  #35
Got it for a decent price. And a direct swap is a plus as well!
Old Nov 23, 2012 | 08:30 AM
  #36
LS1FREEK's Avatar
13 Second Truck Club
I think this is gonna be a great turbo for the 4.8!!! Here's more details on this beast:
https://ls1tech.com/forums/forced-in...ron-speed.html
Old Nov 23, 2012 | 08:58 PM
  #37
foose04's Avatar
Well what the heck, thought there was going to be another BW brother out there.
Haha, good luck with the Netics snail, should work pretty good. (Not BW goodness but work though )
Old Nov 24, 2012 | 09:07 AM
  #38
LS1FREEK's Avatar
Well if its any consolation, We have a good friend here in the small town of Sublette Ks, that bought kazfan30's old turbo 5.3, and it will soon have a BW s475/83mm turbo. We'll have results on it next year
Old Nov 24, 2012 | 06:06 PM
  #39
Jake99's Avatar
I know that was alot of deciding just to change my mind lol, I don't dout at all the turbo you got will out run this one, bw are top notch performance wise. Butit's not gunna out run yours eaither way, got a long way to go before it's ever there, just wanted something with good manners and made more power in the 15-16 psi range.
Old Nov 24, 2012 | 06:51 PM
  #40
lglowe's Avatar
I dont see any reason why the tnetics 78-75 won't be just as good as a Borg with a 83mm wheel. There real close in specs. The billet compressor wheel that foose has and the big race cover will Prolly be the advantage between the 2...
chopperloco
Jul 10, 2016 10:45 PM
thunder550
Oct 8, 2015 04:53 PM
Ls3silverado
Jul 31, 2015 04:22 PM
GMCtrk
Jul 17, 2015 06:39 PM
Cowboy17
Jul 9, 2015 08:22 PM
