tight belt
Old Nov 28, 2009 | 03:38 AM
Most Hated's Avatar
Default tight belt
would it be bad for the pro charger if im using a real tight belt, it holds the tesioner almost all the way back
Old Nov 28, 2009 | 07:40 AM
bai78's Avatar
Mine is similar to what you are describing. It is a real PITA to change out.
So far so good, I have not experienced any ill effects with a tight belt.
Old Nov 28, 2009 | 08:32 AM
phasemaster1's Avatar
Thats perfect youll be surprised how much that belt will stretch with time. I had to use a screw driver to wedge mine on, when I removed blower to change the oil I could just remove the belt off the pulley with my hand.
Old Nov 28, 2009 | 08:59 AM
Rick_Vor's Avatar
It's a good thing. Like phasemaster1 said, the belt stretches over time. Also, when you shift during WOT(at redline for instance), the sudden drop of engine RPM while the blower is still wound up causes the belt to absorb some of the shock and it stretches. That hit is one of the reasons why if your pulleys are out of allignment, you can throw your belt at WOT shifts. You having the belt so tight gives the tensioner more travel to absorb the hit.
I bet if you check it again in a month, you'll have lost a 1/4" of tensioner travel. :-) Nothing to worry about. Focus on that A/F ratio in your other post.
Rick
Old Nov 29, 2009 | 04:27 PM
stoffer's Avatar
I paid my buck-o-five
I bet if you check it again in a month, you'll have lost a 1/4" of tensioner travel. :-) Nothing to worry about. Focus on that A/F ration in your other post.
Rick
Old Nov 29, 2009 | 05:01 PM
XLR8NSS's Avatar
Adkoonerstrator
I got the tightest belt I can get on my Magnacharger with no ill effects. They stretch over time so don't worry about it!
Old Nov 30, 2009 | 02:39 AM
Blown06's Avatar
8 Second Truck Club
I tried to run a gatorback that tight this weekend and it didn't agree with my 7000 rpm shift points. It completely destroyed it on the 2-3 shift. I would say if your gonna be hard on your truck put some miles on that belt to let it strech before you go out hammering on it, unless you carry spares.
Old Nov 30, 2009 | 09:41 AM
stoffer's Avatar
I can't stand gatorback belts on the procahrger, I ended up using the dayco poly cog belts with much better results
Old Dec 1, 2009 | 05:47 PM
the_reaper's Avatar
I just use the 12 rib setup... no belt issues yet on the f1A
Old Dec 1, 2009 | 06:20 PM
bai78's Avatar
I'm surprised you didn't do a cog set-up.
Vortec350ss
Jan 12, 2016 10:36 PM
SlvrSierra4.8
Oct 1, 2015 09:39 PM
murderedSS
Sep 27, 2015 10:16 PM
Justin87gn
Sep 10, 2015 12:06 PM
hackrst
Sep 2, 2015 05:27 PM
