Thoughts& opinions on ATI D1
Old Apr 4, 2007 | 03:33 PM
parish8's Avatar
single digit dreamer
Originally Posted by zippy
I think the compression is fine. You should be able to run 8-10psi on the street and around 12 on pump fuel without problem. That would make for some pretty decent numbers.
that seems prety optimistic. whatever you do have the laptop around and log log log.
Old Apr 4, 2007 | 04:49 PM
zippy's Avatar
I wouldn't say that it'll be easy, but I've worked with a few 6.0L trucks running 9-10psi and 10.9:1 compression on pump fuel. I would think that a 6.7L should be about the same.
Old Apr 4, 2007 | 05:52 PM
YenkoST's Avatar
Quik, you might want to check with a few of the Silverado SS guys with a centrifugal design and see what they are pushing boost wise since the LQ9 is 10:1 compression. Just a thought but it seems like 2004 SSS on here was like 10 psi with alky or something like that with his vortech blower.
Old Apr 4, 2007 | 06:11 PM
Quik's Avatar
5 year bitches!
its just been a thought i had that i wouldnt mind doing in the future. either this or turbo if i dont run the times i want to run NA
Old Apr 4, 2007 | 08:55 PM
YenkoST's Avatar
I know my bud with a TB SS with 10.9:1 compression is going to lower it with heads to 10:1 and run a mp122h or 2.3L if it comes out and only put about 7-8 psi through it.
Old Apr 5, 2007 | 12:12 AM
Keith's Avatar
I'd take a look at what kp over on tech has been able to do with a D1SC on a 346. Pretty stout little combo.
SloSVO
Nov 22, 2020 07:34 PM
AdaMax
May 16, 2016 11:35 PM
Tuckin15s
Sep 23, 2015 09:35 PM
MOBBN
Sep 22, 2015 08:07 PM
