Those running STS in stock form - question
Old Jun 24, 2006 | 09:00 PM
MikeN's Avatar
Default Those running STS in stock form - question
For those of you running a stock STS setup (the basic kit, 6psi, etc). Are you getting good reliability out of the rest of the drivetrain? I've heard from other STS people about drivetrain problems... but most were on other vehicles, and they were also running a bit more boost, running at the track often, etc.
I don't plan on doing track runs, etc... just want to make the truck a bit more fun on the street, and help with some towing. Wanna make sure I'm not looking at potential drivetrain issues before I need to.
Feedback?
Old Jun 24, 2006 | 09:08 PM
kbracing96's Avatar
All I did and I highly recommend to anyone installing a STS, is a shift kit (with no washers in the 1-2 accumulator) and a vette servo. I run my truck pretty hard and has held up strong for almost 25,000 miles and for about a year and a half now at 7 psi. I just recently upped the boost to 10 psi in high setting, but don't use it too often.
Old Jun 24, 2006 | 09:32 PM
bud8fan's Avatar
recommend the regular tranny upgrades that everyone does but stock wont last long for you...you will get a taste of the boost and will want to up the boost pretty quick...it's very addicting that boost stuff is....
Old Jun 24, 2006 | 09:57 PM
MikeN's Avatar
I already have a supercharged car, and a motorcycle... so doubt I'll need to crank the boost up on a heavy truck What are the "standard tranny upgrades" you are speaking of?
I'm interested in how the kit does on the stock drivetrain.
Old Jun 24, 2006 | 10:02 PM
Charged_5.3's Avatar
Corvette servos and a shift kit. Keeping it at a low boost level shouldn't cause any problems with the drivetrain. What kind of problems are you hearing about?
Old Jun 24, 2006 | 10:11 PM
bud8fan's Avatar
this is what i put in mine till i twisted a input shaft into...then a output shaft...now it has all the same accept it has hardned shafts:
here ya go....
TRANSGO 4L60E HD2 SHIFT KIT
700R4 4L60E BILLET 4TH SUPERIOR SUPER SERVO CORVETTE
700R4 4L60E BILLET SUPERIOR SUPER SERVO
TRANSGO 4L60E SEPARATOR PLATE 96UP TRANSMISSION LS1 LT1
4L60E FORWARD CLUTCH ALUMINUM ACCUMULATOR PISTON 4L65E
4L60E 1-2 ALUMINUM ACCUMULATOR PISTON SMALL PIN 4L65E
SERVO RELEASE CHECK VALVE 700R4 4L60E / CORVETTE ETC
LUBEGARD TH350 TH400 700R4 2004R AOD 727 4L60E 4L80E
40,000 GVW THERMOSTATICALLY CONTROLLED TRANNY COOLER.
Old Jun 24, 2006 | 10:35 PM
kbracing96's Avatar
In my option, if your braking hard parts, your not slipping the clutches enough, and if your burning up clutches, your slipping them to much. Kind of a catch-22 It's kind of a fine line, but it seems to be working for my truck. FWIW, Thunder550 put my shift tables in his radix truck and then broke his input shaft and then his out put shaft, but I haven't broke a thing. With my tables in his truck, the way the trans was built, it made the subs thump on pretty much every shift where they are just firm in my truck. Maybe I'm lucky, or it's the way I drive, or maybe its the diff from a turbo to a supercharger, IDK. All I know is my truck is putting about 425 or so to the ground and has hasn't had a issue "yet" with the tranny.
Old Jun 24, 2006 | 10:43 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
This isn't an STS issue, its an torque and hp issue. You may want to ask this again, but instead of STS, use your target HP levels.
Old Jun 24, 2006 | 10:45 PM
bud8fan's Avatar
turbos are easier on trannys since they have to spool up and radix are near instant boost...shouldnt have anymore probs with mine again...i hope...
Old Jun 24, 2006 | 10:53 PM
kbracing96's Avatar
I agree turbo are easier on trannys, but his broke the first time on a WOT 2-3 shift and the second time on a WOT 1-2 shift, so power levels would have been similar (Both at full boost 6000ish)
