supercharger related: replacing broken 6.0 with a .... 5.3?
Old Feb 8, 2019 | 07:43 AM
  #31
03sierraslt's Avatar
Those options are all wrong imo for your desired setup. With a ported head you don’t need quite as much duration to achieve the same effect. If you were not thrilled with the old cam in the 6.0 then you need to consider that. Of the cams you mentioned the first two wouldnt be any better and the last would be a dog down low in a 5.3
Old Feb 8, 2019 | 08:10 AM
  #32
Jim_PA's Avatar
I have no idea what to get, just throwing some FI cams out there to see if I get any bites. Will scratch those from the list.
I spend most of my time driving like a normal person. I do like to pull it up to readline a handfull of times per month. I want it to be all there though when I do it!
Old Feb 8, 2019 | 08:27 AM
  #33
Jim_PA's Avatar
Sounds like I need a mild supercharger oriented cam with meth kit for the full throttle days.
Old Feb 8, 2019 | 08:37 AM
  #34
ill play around with some valve event ideas and send you a pm with some specs.
Old Feb 8, 2019 | 01:22 PM
  #35
terravast4's Avatar
I thought the gt2-3 was a good mild blower cam for the 5.3
Old Feb 8, 2019 | 02:36 PM
  #36
personally, I am not a fan. They were designed in the days of small inefficient compressors and for stock like idle. They were pretty soft off the bottom also in a 5.3
ive tuned a couple and they never impressed me. Many like them, or did anyway.
Again this is just my opinion.
Old Feb 12, 2019 | 09:14 AM
  #37
Jim_PA's Avatar
Ok, how about this one?
​​​​​​​Grind # XA220/350-XA234/345-18+4
Mild Street Performance
Duration at .050: 220/234
118 Lobe Center Angle with a 114 Degree Intake Centerline
Lift with 1.7 Rocker Arm Ratio: .595"/.587"
Recommended Displacement: 5.3-6.2 Liter Engines
Recommended Compression Ratio: 8.5:1-10.0:1
Recommended Headers: 1 3/4" - 1 7/8"
Old Feb 12, 2019 | 09:26 AM
  #38
That has way to late of an exhaust valve close for what you need. Custom is your best bet.
70 TA
13
May 28, 2004 11:54 PM
383montess
Mar 30, 2004 11:45 PM
1BADHD
11
Sep 12, 2003 07:17 AM
TG02Z71
32
Jul 29, 2003 08:14 AM
IM LOWR
17
Feb 11, 2003 09:34 PM
