supercharger related: replacing broken 6.0 with a .... 5.3?
Old Feb 6, 2019 | 08:21 PM
Jim_PA's Avatar
how well did you like the characteristics of your old cam?
I had no complaints, but really don't want anything more radical than what it was. It was a little soft on the bottom end compared to the Lunati I had in there before the S/C, but it was very nice for low RPM light throttle situations. And was definitely stronger than the Lunati at upper RPM range.
Old Feb 6, 2019 | 08:22 PM
Jim_PA's Avatar
Originally Posted by Shaggy2dope
I recently got my PRC stage 1 - 243 heads. They look nice.
They sure do! I hope they work as good as they look! -- thanks for the pix.
Old Feb 6, 2019 | 08:25 PM
Jim_PA's Avatar
I don't know anything about head porting, but what is this?
Old Feb 6, 2019 | 09:04 PM
Shaggy2dope's Avatar
Educated guess is a void/low spot in the factory head casting. TSP hand blends the bowls. Rather than dig in deep to make that one area perfectly smooth, they focused on keeping them even. That one was the worst.
Old Feb 7, 2019 | 08:48 AM
5.3 + CNC heads should be just fine.....What was the actual POWER number you are trying to maintain? And if the bottom end was soft in your opinion with that cam in a 6.0L it will be even worse in a 5.3L. It does not take much cam to make a whole lot of power with forced induction...
Old Feb 7, 2019 | 08:59 AM
Jim_PA's Avatar
The low end was not problematic with the Tick blower cam, it just didn't have as much low end as the Lunati high-lift cam I started out with prior to the S/C. I'm talking about off-idle to 2000 RPM.
Honestly, I have no idea what it made power wise.
On a stock LS2, the e-force is advertised at 599 HP at the flywheel. I had a cam and headers upgrade, so I'd like to think it was closer to 650 at the flywheel. It made enough to slow-walk a Nissan GTR on the highway.
I'm probably going to reach out to some of the cam gurus and see what they'd recommend. I don't want/need something radical at the low-speed/lowRPM driving conditions.
Old Feb 7, 2019 | 09:17 AM
03sierraslt's Avatar
1st step is deciding what you wanna do for heads, then spec a cam once that’s decided. Personally your old cam needed more boost to take advantage of the valve events. You want to optimize cyl pressure if your shooting for something that’s responsive down low. ESP if moving to a 5.3
Old Feb 7, 2019 | 09:19 AM
Jim_PA's Avatar
I have the LS2 heads I plan on sending to TSP for the PRC porting. Unless there's a better option at the $750-$1000 price point.
Old Feb 7, 2019 | 10:16 AM
kbracing96's Avatar
You might look into Katech. They CNC port factory heads for $500 and I believe they are closer to you so shipping should be a lot cheaper.
Old Feb 7, 2019 | 10:25 AM
Jim_PA's Avatar
Is 10-12 PSI a realistic level for a daily driver that sees 10,000 miles a year? I'm really not all that hard on it. Just want the power when I ask for it
