Super/Turbo chargers?
Old Mar 20, 2006 | 09:15 PM
Fellow294's Avatar
Default Super/Turbo chargers?
What is the deal with these electric super/turbo chargers? do they work? doesn't seem like much for $120....?
Old Mar 20, 2006 | 09:48 PM
Scott Mills's Avatar
You would do better to send me 120 bucks.
Old Mar 20, 2006 | 09:56 PM
Fellow294's Avatar
I wasn't planning on flushing money down the toliet on one...just curious if they ACTUALLY did anything good...?
Old Mar 20, 2006 | 11:06 PM
Fellow294's Avatar
any other thoughts?
Old Mar 21, 2006 | 04:17 AM
AintNoHo's Avatar
I read that superchargers under boost roughly use from 75hp to 150hp and more to spin. Of course they help produce a lot more than that. A 100hp electric motor weighs about 800lbs. From these numbers one can see why an electric supercharger is just not feasable.
Old Mar 21, 2006 | 05:37 AM
hemifever's Avatar
Somebody posted that a while back on another board and I read about it. It claims 1psi of boost or an upgrade to 1.5psi of boost. Electric or not....a compressor is a compressor and if it can get 1psi of boost then depending on a bunch of characteristics of your type of engine you could probably have 0 to 20hp. Most likely...you could end up with about 10hp out of that thing.
Now the question is, is that unit large enough to actually take a 400hp engine from vacuum into a 1psi boost state or is it just gonna send parts of 1psi air fragments into the engine? I don't care to try it but it might give a JetChip a run for its money. LOL!!!!!!!!!!!!!!!!!!!!
Old Mar 21, 2006 | 10:03 AM
duwem's Avatar
try it with your moms hair dryier and get back to us.....
Old Mar 21, 2006 | 10:23 AM
KY_BOB's Avatar
...that's pretty much the same thing
Old Mar 21, 2006 | 01:05 PM
AintNoHo's Avatar
There is one that "works". It uses an additional battery and 3 starter motors to turn an Eaton twin screw charger. It will produce 100hp at 6psi......for 15seconds. After that the starters and battery overheat and need to cool down. Also the battery needs to recharge. Electric motors are very inefficient. A lot of the energy just produces heat.
Old Mar 21, 2006 | 03:43 PM
therat1989's Avatar
Electric turbo?
I was wondering if this could possibly work? and can you increse the psi? I'm thinking 30 dollars is not too much money to throw down the toilet.
1slwgto
Oct 1, 2015 01:51 PM
Lthompson
Sep 15, 2015 07:55 PM
wrb002
Aug 31, 2015 12:30 PM
hotyamaha36
Aug 25, 2015 10:32 PM
Steve Sr.
Aug 24, 2015 06:31 PM
