STS vs Magnacharger
#51
I dont see how... 5psi is 5psi... ???
If he has his Wastegate Reference to this Intake Manifold they should both have 5psi...
Correct??
I think your talkin about something else...
CFM... i would think that for 5psi on the 6.0 it would have more air, compared to the 5psi on the 5.3?
Correct??
What I am saying is PSI does not tell the whole story. If I took a t67 turbo and bolted it to a 6.0 it would make lets say 600hp at 8psi. Now I could take a t76 and it will make alot more hp at the same psi. You have to look at efficicency of the blower as well. Same thing with the 112 vs 122. The 122 is going to make more power than the 112 at the same psi on the same motor. Because its getting more air at the same psi or is it because it's just compressing more effectivly. One is going to be able to compress more air at the same psi. IAT's are also an issue that is not being said here. Like throttle bodies, the bigger one flows more cfm normally, right?
#52
#53
Thats a Z06, not a vette. You left before all this happened anyway. You missed me and Lance have a go on street tires.
Side note. I found where I was leaking boost last night and my next trip to the track will be stronger.
If I mail you a copy of a dvd, will you post it Kyle???
#54
Ok i got ya now man... i wasnt that far off on my thinking.....
appreciate it!!!
#55
#56
I hope this makes to sense to anyone else.
Paging Dr. Parish....
I don't mean to hijack, but this is a good discussion. Perhaps to a new thread?
#57
A bigger turbo has the ability to flow more at the same PSI, but with no changes to the engine, it will not flow more at the same PSI.
The dyno will argue you on that one. Ask the people that have upgraded turboes and made no other changes "same psi" and made more power!
#58
The dyno will argue you on that one. Ask the people that have upgraded turbos and made no other changes "same psi" and made more power!
#59
'I'm just the electrician'
'When you do things right, people won't be sure you exist at all'
#60
Originally Posted by alanderson1978
Something about this doesn't seem right to me. I agree that PSI at the manifold is not the whole story(forget about PSI at the turbo or I/C), but I think that has more to do with downstream components. Flow is based on the difference in pressure between the intake and chamber, and the restriction in flow. If you had 2 identical engine/turbo setups, except one has ported heads, the ported one would flow more at the same PSI. A bigger turbo has the ability to flow more at the same PSI, but with no changes to the engine, it will not flow more at the same PSI.
But I still think that all the bends and turns in the intake piping of the sts setup is going to slow the amount of air going to the manifold (more restrictive). You may have 5 psi of preasure but not same amount of air. Kind of like the example you gave ported and non ported heads. I remember a change of manifold boost preasure just from changing intakes from the truck intake to ls1. I think I lost boost if I remember correctly. Its like blowing through a straw vs blowing through a garden hose. THe garden hose will need more air to make 5 psi.
