STS turbo limitations
Old Dec 9, 2010 | 10:40 PM
kalikid06's Avatar
Default STS turbo limitations
I currently have a garrett T-04E (60mm) being used on an STS kit. How big a turbo can I fit with that flange. I plan to upgrade to a 76mm turbo in the future and it would be nice to slap it onto the existing STS hot pipes. What do you guys think?
Old Dec 10, 2010 | 10:55 AM
kbracing96's Avatar
A Master Power T70 or T76 P-trim turbo will bolt right in there. The only difference is the MP's have a 2 1/2" outlet on the compressor where the Garret as a 2", but nothing a new coupler can't fix.
Old Dec 10, 2010 | 09:41 PM
slowec's Avatar
Old Dec 10, 2010 | 10:01 PM
kalikid06's Avatar
And how much is a MP T76 P-trim? And how well would it feed a 6.0L?
Old Dec 10, 2010 | 10:08 PM
SRTKLLR's Avatar
I upgraded the 60-1 to a 76 on the Hemi and I got a new pipe from STS because the compressor outlet was bigger. The #1 pipe on the STS kit tapers down to fit the 60-1 so by getting the bigger turbo you will be good.
So normally the pipe attached to the compressor outlet is 2" and uses a pipe that is 2" on one side and 2 1/2" on the other side. It stays that way until you hit the cabin then in goes to a 3" and then it changes again before it goes into the tb.
Old Dec 11, 2010 | 04:46 PM
kalikid06's Avatar
So all I need to do is get the #1 pipe that will accomodate the bigger turbo? Also, what diameter is the turbine discharge on the T-76?
Old Dec 11, 2010 | 08:35 PM
02'Z71ONDUBZ''s Avatar
you should be able to order a 2.5" silicon coupler, the discharge should be a 2.5". It all really depends on what version of the MP T76 you get. Try looking up the online catalog, it will answer both of your questions.
Old Dec 12, 2010 | 12:15 PM
kbracing96's Avatar
They are $750 shipped. It would feed a 6L just fine
Old Dec 13, 2010 | 09:10 PM
Casey2323's Avatar
ummm...... You know better then to ask all the foolish questions on turbo size.... WHY did you change your screen name for this site??... 76mm will be fine for a 6.0 when u get one but your far from done with that 4.8 man.. put a cam in it... that will help you get rid of all that crank case pressure and make some power !
Old Dec 14, 2010 | 01:35 PM
kalikid06's Avatar
I tried to use my other screen name but this site wouldn't let me
Zizzle
Oct 19, 2017 08:44 PM
jeff.ellis
Aug 18, 2015 10:34 PM
ZO6Ted
Aug 12, 2015 07:50 PM
Deceptarado
Jul 8, 2015 05:24 PM
