STS in side!!
Old Aug 3, 2007 | 11:56 PM
Quik's Avatar
5 year bitches!
what the hell is the syty shuffle
Old Aug 4, 2007 | 04:38 AM
Spoolin's Avatar
GFYS and STFU
Put car in Neutral, rev truck up to just before redline 3 times in quick succession to spool up turbo. When RPM's drop back down shift into Drive and brake stall to 3500 rpm's and when your nuts are in your throat let go of the brake pedal.
At least that's how I did it with my old Ty. Sure miss that little car!
It was meant as a way to get more boost off power braking by spooling the turbo up before the hard launch. Worked really well to tell you the truth. Never got any numbers but my SOTP Dyno could notice the difference.
Old Aug 4, 2007 | 08:56 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Here's what I meant:
1) put your foot on the brake and mash it hard
2) rev the motor up to moderately high rpm and let it fall
3) as the RPMs fall, push harder on the brakes and you will feel the pedal move even tighter
4) spool up as necessary
With that I can spool to pretty much whatever psi I want to launch at. Slightly different method than what Spoolin did, but the same intent and result
Old Aug 4, 2007 | 07:59 PM
05crew's Avatar
not to sure about that brake spoolin ****....but ill give it a try.. yall are the pros here! thanks for all the answers! i will post dyno thanks!
Old Aug 4, 2007 | 08:09 PM
05crew's Avatar
oooo... and the blowing sound how can u fix that! i heard that u can vent wastgate into ex. pipe. true or not.......?
Old Aug 4, 2007 | 11:03 PM
I AM A MOTHERF*CKER
Yes, but you get better performance just dumped to atmosphere.
Old Aug 4, 2007 | 11:04 PM
I AM A MOTHERF*CKER
Take it easy until you get comfortable. Start by spooling to 3 psi or so. 6psi+ can be a hand full!
Mr. Chainsaw
Oct 18, 2015 08:00 PM
Roody0209
Sep 17, 2015 09:06 AM
fortune46x
Sep 16, 2015 08:18 AM
