STS in side!!
Old Aug 3, 2007 | 05:38 AM
05crew's Avatar
Default STS in side!!
i have just got my first kit! and would like to know on a LQ9 how much boost can i run. i have meth inj. also. what kind of power are u seeing? this truck is AWD and i have a 3200 stall. i hope i will be happy with the power!
thanks for the replys
Old Aug 3, 2007 | 06:14 AM
slowec's Avatar
Give us all the info you can on your truck. You could run 6 to 12 lbs with meth and tuning. I personally would stay below 10 for safety. You will love the power. You should see 400 to 650 with that combo on a rwd, not sure about awd tho. What size turbo? congrates!!!
Old Aug 3, 2007 | 07:30 AM
ZO6Ted's Avatar
Just got mine on last week and it's like night and day. Check out Wilde Racing!
Old Aug 3, 2007 | 08:47 AM
Turbo 6.0's Avatar
Good luck man. I can answer any tech questions that you might have while installing. If you have any feedback for me that would be helpful too.
Old Aug 3, 2007 | 09:04 AM
05crew's Avatar
its a t67, i am getting it install... next week, i hope it will get in the low 8s in a 1/8 mile! do you want to stall up at the line for launch, or flash the cov.?
thanks for the help
Old Aug 3, 2007 | 10:20 AM
365ZUM's Avatar
On my LQ9, I run 9lbs full time on the street with no meth. I have 8k miles on the kit with no issues whatsoever. Personally, I would feel comfortable with 12psi as max boost w/methanol on the stock bottom end with an excellent tune. Much more, and you'll likely run into fuel starvation issues.
Old Aug 3, 2007 | 09:02 PM
gotboost30's Avatar
Registered User
all I have to say is wow
Old Aug 3, 2007 | 11:41 PM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
thanks for the help
Is it the .96 A/R or .83?
I ran up to 12lbs with meth on my LQ9 and GT67 combo, however, the stock fuel pump could not keep up.
Did you get 42lbs injectors as well? Tune?
That stall is about perfect for that turbo. You should be flashing into serious boost...
I AM A MOTHERF*CKER
Old Aug 3, 2007 | 11:42 PM
I AM A MOTHERF*CKER
thanks for the help
Try both. Mixed results there... Some flash the converter and get better 60' times, others swear by the syty shuffle (myself included )
