STS in side!!
GFYS and STFU
Originally Posted by Quik
what the hell is the syty shuffle
At least that's how I did it with my old Ty. Sure miss that little car!
It was meant as a way to get more boost off power braking by spooling the turbo up before the hard launch. Worked really well to tell you the truth. Never got any numbers but my SOTP Dyno could notice the difference.
Here's what I meant:
1) put your foot on the brake and mash it hard
2) rev the motor up to moderately high rpm and let it fall
3) as the RPMs fall, push harder on the brakes and you will feel the pedal move even tighter
4) spool up as necessary
With that I can spool to pretty much whatever psi I want to launch at. Slightly different method than what Spoolin did, but the same intent and result
Originally Posted by 05crew
oooo... and the blowing sound how can u fix that! i heard that u can vent wastgate into ex. pipe. true or not.......?
not to sure about that brake spoolin ****....but ill give it a try.. yall are the pros here! thanks for all the answers! i will post dyno thanks!
Take it easy until you get comfortable. Start by spooling to 3 psi or so. 6psi+ can be a hand full!
