STS Question
Old May 20, 2006 | 08:01 AM
  #21
quicksilverado's Avatar
Originally Posted by MrXerox
What do the duty cycles look like at the standard 6psi on the stock 24s then?
they are right on the edge at 6 psi.
Old May 20, 2006 | 10:06 AM
  #22
kbracing96's Avatar
Here is what they are at 10psi on a 4.8 if that helps.
Old May 20, 2006 | 05:30 PM
  #23
greentahoe's Avatar
does that say 189% duty cycle??
Old May 20, 2006 | 06:51 PM
  #24
Mort's Avatar
Cool
Now that doesn't look too good. LOL
Duty Cycle B1 182.829%
Duty Cycle B2 189.710%
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
KR 1.3 could be worse
On the other hand IATs are only 122*F and RWHP is 445.
Results of the next run
Old May 20, 2006 | 08:00 PM
  #25
Charged_5.3's Avatar
Originally Posted by quicksilverado
I had the same setup and it worked out fine. You will have to lose the muffler. You can remove the cats also and it will spool up about 300 rpm faster.
So you can have a loudass exhaust with the STS? I thought that the turbo acted like a muffler and quieted the exhaust? So I can run Longtube headers and no cats, with an all around 3" Y-pipe to an X-Pipe and bullits?
Old May 20, 2006 | 08:41 PM
  #26
parish8's Avatar
single digit dreamer
Originally Posted by Charged_5.3
Probably, but the motor won't last as long though.
the motor will last a prety long time if you never mess up the tune.
Old May 21, 2006 | 01:54 AM
  #27
kbracing96's Avatar
Why yes, it does
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
Wasn't my truck, it was another members, (you know who you are Todd) He did get some injectors on it and it's all good now
Just posting this as a reference, in case some think they can just uses the stock injectors
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
andrewlong
Sep 8, 2015 10:25 PM
