STS Question
#24
Now that doesn't look too good. LOL
Duty Cycle B1 182.829%
Duty Cycle B2 189.710%
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
KR 1.3 could be worse
On the other hand IATs are only 122*F and RWHP is 445.
Results of the next run
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
#25
Originally Posted by quicksilverado
I had the same setup and it worked out fine. You will have to lose the muffler. You can remove the cats also and it will spool up about 300 rpm faster.
#27
Originally Posted by Greentahoe
does that say 189% duty cycle??
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
Commanded AFR 9.03
Actual AFR 15.43
HO2S11 0.061
HO2S21 0.039
Wasn't my truck, it was another members, (you know who you are Todd
) He did get some injectors on it and it's all good now
Just posting this as a reference, in case some think they can just uses the stock injectors
carid
Sep 10, 2015 09:07 AM
