sts install at home
Old Apr 29, 2006 | 02:30 AM
ogkevin13's Avatar
Banned
Default sts install at home
you guys think an sts install would go pretty good at home or would it be 2 difficult to do. and what is their to look out for
Old Apr 29, 2006 | 06:22 AM
hemifever's Avatar
Exhaust pipe welding is always the best way to go. If you can do that, everything else should be a garage job.
Old Apr 29, 2006 | 07:14 AM
TG02Z71's Avatar
You should be ok doing it at home.
I did mine at work where it was warm and dry but had no lift either.
The kit goes on pretty easy.
Some things to be carefull of are drilling the turbo oil supply hole and tapping it with a 1/8-27 tap. Drill the hole a little smaller than the recomended size or when you go to tap it your fitting will be loose and leak. Its pretty hard to drill a straight hole on size in cast aluminum with a hand drill.
The pipe that used to go to your muffler and now supplying the STS input to the turbo needs to be welded, the stock pipe will not be round and will have bad gaps and leak exhaust. If you get a pipe spreading tool you may be able to get it round enough for it to seal with just a pipe clamp until you get it welded.
Before you start ripping off all your stock parts lay the pipes out on the floor in kind of a mock up stage to get a better idea of how the pipes go on.
Take your passenger side inner fender well cover off and your passenger tire too, it will be much easier putting the pipes together and getting the clamps on.
Do not over tighten the couplers on your MAF, its plastic on one end and can be malformed or evn crack if you get too aggressive with it.
Use the intake maifold for your boost reference instead of the turbo's output housing, make sure you plug the output housing hole if you don't use it.
If I think of anything else I'll post up, I'm still half asleep here.
Good luck on your install.
Old Apr 29, 2006 | 12:28 PM
ktmrider's Avatar
Did 2 installs in a home garage with absolutely no problems ( 6 hrs on first, 4 on second ).
BTW I also have done 2 de-installs with no problems either. The kit actually comes off quicker ( 2 hours ). Good for those who lease or sell later....
Old Apr 29, 2006 | 11:01 PM
Wilde Racing's Avatar
How do I change this text
I did mine at home as well.
Old Apr 29, 2006 | 11:55 PM
Injected1's Avatar
we did mine in my buddies garage at his home...we are just kinda cruising, but we are about done...few little issues, but those are steming mainly from the fact that I have major changes planned for down the road (9psi WG spring should be on order soon
Old May 1, 2006 | 02:40 AM
ogkevin13's Avatar
Banned
ok well i will give it a try. so the best thing to do would be strech out the stock pipe over the sts feed. and the oil supply shouldnt be a problem sence i had the kit installed be4 but i didnt do the install
Old May 1, 2006 | 09:43 AM
vanillagorilla's Avatar
I did mine at home on a gravel driveway. It only took me a Friday night to do it.
Old May 6, 2006 | 10:09 PM
snakeyz 03's Avatar
wow .
Old May 7, 2006 | 07:20 AM
Lord Aries's Avatar
HAHAH I love your signature thats great, I have to add that to mine...
Choda
Jan 22, 2026 02:03 PM
jeff.ellis
Aug 18, 2015 10:34 PM
LETHL_SS
Aug 16, 2015 06:58 PM
ZO6Ted
Aug 12, 2015 07:50 PM
Ammadien
Jul 22, 2015 08:50 PM
