STS install help
I am about to install an sts kit with gt67, fmic, walbro intank, 43lb injectors and a tune from nelson. all of this is going on at the same time. When i first start the truck after the install is there anything that i need to do besides just double check everything. Should i let it run for awhile to let the computer check out what is going on, take it out and cruise for awhile. Any help would be great. Thanks
Wheres your Wideband? any type of Datalogging equip? I suggest just take a few nice easy cruises and make sure all sounds good. Then just keep driving a little harder and see how it runs, I wouldnt do a hard W O T run till ya get a way to monitor your A/F ratio. 1 time lean on top end could mean boom. I do know Nelson tunes on the safe side most times but not always.Good Luck.
forgot to add that i am getting an air/fuel gauge, boost, interceptor and elec. boost apexi avc r boost control. also what other gauges should i get? THinking about a fuel pressure gauge as well.
Don't forget the love for the tranny, the transgo kit would be a short term solution for the drive train until you catch that virus from some of the other Forced Induction members on here. Then its FLT all the way.
I got the kit and the boost gauge is an autometer mech. gauge, it has a small tube that comes from it, do i just break off the spot on the manifold and stick it in or do i have to have a connector of something to hold it in?
is that air/fuel gauge a wideband if not dont waste your money for a narrowband gauge thats just a purdy light show
id put a boost, fuel press., and wideband gauge on ANY FI setup
you should get a trans temp gauge too if you dont have one in your dash cluster, but the interceptor might cover that IDK
LCHEE
Oct 24, 2020 04:10 PM
ZO6Ted
Aug 12, 2015 07:50 PM
zblee
Aug 3, 2015 03:45 AM
