Stock Fuel pump
I'm going to add a t-74 or 76 turbo at the beginning of the year. My question is do I have to change the fuel pump right away or will it last for awhile. I plan to run around 10lbs of boost. The motor is a stock lq4 with stage 3 heads. If I change it what is the best route in tank or a aeromotive style?
Walbro 255... you can find them from $100-150 all day long... and you might need some 60lb injectors for that much boost??
At 10 psi with your 6.0L you should make 550rwhp if not more. If you plan to run more boost later on, or do not plan to use methanol injection then it would be good to oversize your fuel system now. A single 255 in tank will be close to its limits at that power level.
Some guys will run a 255 with a Boost a pump. The BAP will increase voltage to the fuel pump when you are under boost so it can deliver more fuel. Others have modified the bucket that the pump sits in inside the tank and installed 2 255 pumps.
lxcoupe
Jul 21, 2015 02:12 AM
Mossyoakglock
Jul 17, 2015 08:30 AM
