Stock 5.3l looking for a Supercharger.
Old Jul 26, 2019 | 10:07 AM
thunderwolf's Avatar
Registered User
Default Stock 5.3l looking for a Supercharger.
I have a 5.3l (2006 Silverado 1500 z71) in my truck and am looking to supercharge it. I know it's not the cheapest way to make power but I just want a supercharged truck. I will be getting a cat back exhaust system soon too for better sound and more flow. Any recommendations for superchargers? Want 400+ horse with the supercharger exhaust injectors and maybe a air filter. My transmission is also probably on the way out so recommendations for that? I'm thinking a 4l80e or a 6l80 because it falls on its face as soon as it hits 4th right now so more gears should help that some. If the 6l80e bolts up or I can get an adapter plate is it worth it? I do tow with it sometimes and load the bed with stuff.
Old Jul 26, 2019 | 10:25 AM
madmann26's Avatar
Stick with the 4l80 and a good converter.
As for supercharger....it really depends on where you want your power. Off-idle or top? Both types will pull through the red line. They just make their power a little different.
I've had a Whipple and it's fun as hell. If you boost over 10psi then you're going to need meth to keep the charge cool.
PDS blowers (off-idle power)
1. Whipple
2. Magnacharger
Centrifugal blowers (needs rpm to make power)
1. Procharger (intercooled)
2. Torqstorm (not intercooled)
Turbo
1.Trick Turbo
2. KBRacing
3. others
Based on what you mention in your post, you're going to tow. That alone would make me want a Whipple or Magnacharger but you can tow with a Procharger or Torqstorm.
Also, both like a different type of converter. PDS blowers like a tighter converter where centrifugal typically like a looser converter to help build boost.
You also are going to need fuel. Either a larger intank pump, a boost a pump or fully convert to a return system.
We can throw ideas all day long.
Old Jul 26, 2019 | 12:22 PM
Registered User
1. Whipple
2. Magnacharger
Turbo
1.Trick Turbo
2. KBRacing
3. others
Yeah I definitely want torque off the line and I'm not sure if I have a 4l80 or a 4l60 in my truck. Haven't gotten a research. Do you know off the top of your head which it would be?
Old Jul 26, 2019 | 12:25 PM
ZO6Ted's Avatar
4l60 pos for sure on a 1500
Old Jul 26, 2019 | 12:27 PM
madmann26's Avatar
@ZO6Ted is right.
Dont even think about using it.
Old Jul 26, 2019 | 02:51 PM
Registered User
@ZO6Ted is right.
Yeah I'm swapping a new one in. Should I worry about building a 4l80 or just get one stock?
Registered User
@ZO6Ted is right.
Old Jul 26, 2019 | 03:08 PM
smokinlmm's Avatar
Built 4l80 and I'd go magnuson or whipple from what you've said you want...
Old Jul 26, 2019 | 03:51 PM
ZO6Ted's Avatar
Hey smokin you don't think a stock one would be ok with 400+ hp? I guess used you get what you get though huh.
Old Jul 26, 2019 | 04:10 PM
madmann26's Avatar
A stock one is fine. I have a stock built 80e with the only modification internally being the dual-feed mod.
