Stepping up from the t67 to a t76
Old May 14, 2007 | 07:52 PM
quicksilverado's Avatar
Default Stepping up from the t67 to a t76
This should make a little difference in the seat of the pants.
http://www.cablebandit.net/gallery/v..._1473.JPG.html
[url]
Still have to swap out the injectors, add another fuel pump, move the oil return line to the oil pan and do a few other little things. The exhaust housing is ceramic coated and the y-pipe and exhaust manifolds are at the coaters now.
Click on Dave at the top of the page and there are a few pics of the install.
Old May 14, 2007 | 08:14 PM
8ALTNG's Avatar
Nice man. That should put you into the 10's on slicks easy. Cant wait to see the results.
Old May 14, 2007 | 08:37 PM
Wilde Racing's Avatar
How do I change this text
[url]
Looks like you move the turbo closer to the engine by a few feet, looks GOOD.
Old May 14, 2007 | 08:49 PM
Bill Reid's Avatar
Wow! Looks good
Bill
Old May 14, 2007 | 09:12 PM
Its aout 20 inches closer to the engine. Should spool just as fast as the 67 did.
Old May 15, 2007 | 08:15 AM
slowec's Avatar
what is to come of the 67 ?
Old May 15, 2007 | 09:22 AM
TurboBerserker's Avatar
I AM A MOTHERF*CKER
Cool Dave! Can't wait to hear how that works out for you.
How are you running the air filter?
My twins will be 10-12 inches back from there (right after the crossmember).
Old May 15, 2007 | 10:54 AM
zippy's Avatar
Very cool, how much boost do you run?
Old May 15, 2007 | 12:24 PM
As of now the 67 is spoken for. If that changes I will post up.
Erik, the filter will go on the other side of the driveshaft, under the drivers seat.
I was at 12 psi on the 67. Will start around 10 on the 76 and see how that feels. I'm guessing it will end up in the 14-15 psi range.
Old May 15, 2007 | 12:47 PM
Spoolin's Avatar
GFYS and STFU
Looks Good!
