Started Trick install on my truck
Old Aug 19, 2007 | 07:14 PM
  #31
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by TrickPerformanceProducts
Don nice install, looks really clean. Like the DP connection to stock exhaust,(looked coated ) the 07's have a flex joint after that connection point in your pic.
Question for you, I notice you ran the breather hose directly into the airfilter. I guess that is what I am seeing in the pic, anyway.
Do you have an oil seporator in that line?
What does the butt dyno tell you?
Hmm, you caught the PCV line . I always run them like this first to pull alittle vacuum.It is straight to both valve covers.Time will tell if I need a seperator.Some vehicles do,some don't depending on how tight the motor is.I just know there is no oil smoke or smell.
The exhaust and intercooler pipes are painted with 1200deg. aluminum paint.Looks just like it was coated and lasts pretty good.
Old Aug 20, 2007 | 12:18 PM
  #32
Slowhawk's Avatar
LS1Tech Sponsor
Weel,my jobs at work got screwed up so I had time to dyno.This is at 7lbs of boost,11.5-1 A/F, 17 degree's of timing.All fully street tuned with this 1 dyno pull in 3rd.
Old Aug 20, 2007 | 01:06 PM
  #33
WJ MARK's Avatar
Those are some pretty good numbers! I still haven't dynoed mine but hopefully its somewhere in that neighborhood.
Old Aug 20, 2007 | 01:28 PM
  #34
TrickTurbo's Avatar
Truck Sponsor
Not glad your other jobs got screwed, but SWEET you got to dyno the truck. Nice numbers I think, for no meth, very safe street tune.
Now that tranny probably is not going to like you....
later
Old Aug 20, 2007 | 02:46 PM
  #35
Slowhawk's Avatar
LS1Tech Sponsor
For a 500hp rated turbo this will go past that easilly enough.150hp from only 7lbs is great.Just think what 12lbs is going to do
Old Aug 20, 2007 | 03:07 PM
  #36
Bill Reid's Avatar
Thats what I'm talking about!
Bill
Old Aug 20, 2007 | 03:25 PM
  #37
03sierraslt's Avatar
Nice gains, what are the specs of that 216 cam?
Old Aug 20, 2007 | 05:37 PM
  #38
Slowhawk's Avatar
LS1Tech Sponsor
It's a Slowhawk special Cam Gained 40rwhp NA and was actually speced for a Procharger.Worked good for this turbo with stock converter too.
Old Aug 20, 2007 | 06:24 PM
  #39
XLR8NSS's Avatar
Adkoonerstrator
I don't know if I've seen it mentioned before. What size turbo is that?
Old Aug 20, 2007 | 08:07 PM
  #40
8ALTNG's Avatar
nice job Don. Cant wait to see it run at truck nationals.
