Started Trick install on my truck
Old Aug 20, 2007 | 08:08 PM
  #41
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
So will you be swapping the cam for a reverse split instead of the standard split you are running?
Old Aug 20, 2007 | 08:35 PM
  #42
Slowhawk's Avatar
LS1Tech Sponsor
Naaa, too lazy.I'll raise the boost and see how she does.Long term plan is to do the 4L80 then switch to a 408ci setup.I would like to run 10's easilly while towing my 7 second car
Anybody find the money tree yet
Old Aug 20, 2007 | 08:42 PM
  #43
TrickTurbo's Avatar
Truck Sponsor
Originally Posted by XLR8NSS
I don't know if I've seen it mentioned before. What size turbo is that?
62-1 .81a/r
Standard turbo for the INTRO kit.
Old Aug 21, 2007 | 08:32 AM
  #44
FarmTruc's Avatar
Performance Trucks Sponsor
Originally Posted by Slowhawk
It's a Slowhawk special Cam Gained 40rwhp NA and was actually speced for a Procharger.Worked good for this turbo with stock converter too.
Great numbers, get to the track, I'd like to see what it runs.
That's about the same cam I have in my Av and they work great! It kept most of the lowend and it's very hard to pick a bad cam, around that size for a turbo.
later,
allen
Old Aug 21, 2007 | 02:38 PM
  #45
TurboBerserker's Avatar
I AM A MOTHERF*CKER
"Everybody wants 1000hp with a 400hp budget"
Old Aug 21, 2007 | 02:41 PM
  #46
Slowhawk's Avatar
LS1Tech Sponsor
Like that,huh
I get called almost everyday from someone that wants to make 1000rwhp and daily drive it but they think they can do it for $15k or under. I'm getting tired of it.
Old Aug 21, 2007 | 02:43 PM
  #47
Slowhawk's Avatar
LS1Tech Sponsor
later,
allen
I'm still working on the tranny tune right now.It's getting overpowered on the shift's. Hopefully soon it will be set.
Changed the filter setup and added my old cold air type of filter.Looks like it should be better than before
Old Aug 21, 2007 | 03:10 PM
  #48
TrickTurbo's Avatar
Truck Sponsor
Looks good, let me know if you need anymore of that flex tubing. I ordered a BOX by mistake, no returns... ouch...
That set up should help pull in some cooler air!
Rick
Old Aug 21, 2007 | 03:59 PM
  #49
Bill Reid's Avatar
Meth tank location is pimp
Bill
Old Aug 21, 2007 | 05:01 PM
  #50
1slow01Z71's Avatar
Ebay heat shield and filter FTW
