Started Trick install on my truck
Old Aug 16, 2007 | 10:44 PM
Slowhawk's Avatar
LS1Tech Sponsor
Yes,that is the drain.Have drilled pans many times for drains but ussually over the oil level sender.I tried this spot from Nelsons advise.There is plenty of room there,just load the bit up with grease to get the shavings.I also use a step bit,the kit uncludes the bit and tap but I was too lazy to break out the 1/2 drill to hold the bit.(kit needs a turned down shaft 9/16 bit)
Old Aug 16, 2007 | 10:55 PM
Bill Reid's Avatar
The drain is... uhh... unique. I suppose it works if its been recommended. Please give us your honest feedback if you experience problems with it. Otherwise it certainly looks like an extremely simple and accesible point to tap the pan for drain.
Bill
Old Aug 17, 2007 | 06:48 AM
Slowhawk's Avatar
LS1Tech Sponsor
Bill
It's well above the oil level so I don't see a problem.If it sucks I'll let people know.
Old Aug 17, 2007 | 08:42 AM
WJ MARK's Avatar
Looking good! The kit is easy as hell to install. The most time consuming part is taking off your old ****! The rest goes on really easy. Looking forward to see if you like it as much as I do.
Old Aug 17, 2007 | 09:05 AM
TrickTurbo's Avatar
Truck Sponsor
Ok, we need to get a step (short) drill bit....
Rick
Old Aug 17, 2007 | 04:30 PM
Slowhawk's Avatar
LS1Tech Sponsor
Turbo kit was quick, intercooler piping is kicking my ***.Will be running tomorrow.
Old Aug 17, 2007 | 04:41 PM
WJ MARK's Avatar
Thats the same problem I had. Taking the old **** off was a bitch. putting the new **** on was eeeaaassy!. Intercooler was a bitch! my main problem was clearing the fan and alternator, go too high over the alternator then the hood won't close. She'll be fun when she's all done!
Old Aug 17, 2007 | 07:25 PM
TrickTurbo's Avatar
Truck Sponsor
pics..
Old Aug 17, 2007 | 08:48 PM
Slowhawk's Avatar
LS1Tech Sponsor
Originally Posted by TrickPerformanceProducts
pics..
I have them on my camera. Sometimes I forget how good the lifts are at the shop.Made a nice pipe setup from the downpipe to cat-back and of course burnt my arms up The intercooler pipes are twisted every which way to hug the frame.
Old Aug 18, 2007 | 12:29 AM
Bill Reid's Avatar
Pfff... intercooler plumbing... high and tight for the low riders... hhehehe
... one more Top Mount... coming to please... I am certain
Bill
