Spring selection for Precision 46mm
Old Mar 21, 2016 | 03:43 PM
lxcoupe's Avatar
Default Spring selection for Precision 46mm
Guys I have been puttsing around on a 3lb spring, I'm headed to dyno this Thursday. I have an Innovate SCG-1 controller. I want to make 10-12psi, but I don't want to hassle the tuner with a spring change on the dyno. I was thinking of combining the 'natural' and the 'green' springs, the chart says 10.5psi, and then using the boost controller above that. Does that sound reasonable?
Old Mar 21, 2016 | 03:59 PM
Choda's Avatar
bring you allen wrenches lol
Old Mar 21, 2016 | 04:02 PM
lxcoupe's Avatar
Why when the solenoid can be used to raise past the mechanical spring pressure?
Old Mar 21, 2016 | 04:03 PM
Jake75's Avatar
and use your strong hand! that spring pressure is no joke..
I used a 7lb spring spring in mine and used the boost controller to go up to 12 psi
Old Mar 21, 2016 | 04:17 PM
lxcoupe's Avatar
That sounds reasonable. 600/636 are some nice numbers! Is that from a 5.3?
Old Mar 21, 2016 | 04:21 PM
Jake75's Avatar
yes it is
vicalma03
Nov 29, 2020 05:05 PM
LARRY01Z28
14
May 2, 2016 10:37 PM
Sexyrado327
Mar 21, 2016 11:55 PM
TAPyvehc93
Mar 20, 2016 11:08 AM
JCunningham
Mar 17, 2016 04:48 AM
