Reverse split cam question
Old Jan 22, 2012 | 10:46 PM
Hawaiian_Built's Avatar
12 Second Club
Default Reverse split cam question
I'm thinking about going the turbo route in the near future. I have the following cam installed 220/218 .564/.562 114LSA. I came out of a turbo'd LQ4 RCSB. I've done some reading and not everyone agrees with reverse split cams for turbos. I plan on leaving this cam in when I do the turbo but the difference is that my truck is a 5.3l. I know there are many variables but what is your opinions on running this cam in a 5.3l turbo application?
Old Jan 23, 2012 | 04:40 AM
JoeyGC5's Avatar
I'm running an old SLP 234/228 0.571/0.582 113 cam in my PT88 5.3 rcsb. Its a dog below 3k, but cruising is comfortable, idle draws attention, and it makes a butload of power in boost. This cam was in my ex-gf's 6.0 camaro years ago and made good NA power, so I thought it's free why not give it a shot. Stock48 made killer power with a 212/212 and there are others who will suggest a more suitable cam, but if money is tight give it a go.
https://www.performancetrucks.net/fo...me-fun-494749/
Old Jan 23, 2012 | 11:18 AM
12 Second Club
Thanks for the input. I wasnt planning on changing it out unless results arent that great. I figured since its already in there why change it. I just wanted to hear some opinions on the reverse split cams. I have seen some pretty impressive numbers/times
Old Jan 23, 2012 | 12:05 PM
Atomic's Avatar
I have a gauge for that
I had a 236/230 and hated it with my turbo.
Old Jan 23, 2012 | 01:45 PM
12 Second Club
^^^^ you had a 6L right. Maybe too big for that heavy truck
Old Jan 23, 2012 | 02:45 PM
Atomic's Avatar
410, so 6.7L
Old Jan 24, 2012 | 05:07 PM
FarmTruc's Avatar
Performance Trucks Sponsor
I'm using a reverse split in mine and it works just fine.
Old Jan 24, 2012 | 06:55 PM
gavin2005's Avatar
im running a reverse split cam that pat g spec'd for me.seems to work good.i will have times shortly
ARC
57
Feb 21, 2022 10:54 AM
Jake75
Aug 5, 2015 01:26 PM
USMCvet0311
Aug 1, 2015 07:45 AM
WICK3DxGATA
Jul 21, 2015 06:59 PM
MileHighSierra
Jul 12, 2015 12:23 AM
