RCSB Z71 / BW S372 / E85 / Thoughts on Power?
Old Sep 15, 2013 | 02:31 PM
  #21
smokeshow's Avatar
Mod with training wheels
Originally Posted by HydroStream6
One of the reasons the Walbros suck for high pressure is that they have a relief valve that opens at 75psi. Making this valve inoperable helps a lot with the fuel flow falling off. They still aren't as good as some of the other pumps out there, but it helps.
Ah. Well I was talking about lowering the fuel pressure, not increasing it.
Old Sep 15, 2013 | 02:36 PM
  #22
oakley6575's Avatar
Jake, when you lower the pressure like that to squeeze more out of the pumps, do you change the IFR in the tune? I've always wondered if that will fix fueling or do you have to retune the MAF/VE?
Old Sep 15, 2013 | 02:46 PM
  #23
The only reason to lower the fuel pressure would be to get the pumps into a range where they don't drop off at the high end (say 58 base + 20 boost, 78 lbs). The Walbros drop off a lot over 75 lbs because of the relief valve. Disabling the valves makes them not drop off as much so you can still run higher pressures.
Old Sep 15, 2013 | 03:34 PM
  #24
smokeshow's Avatar
Reducing the IFR for the new fuel pressure seems to take care of everything as long as your injector data is good. I always check VE to make sure everything is good though.
The pumps flow less at higher pressures, but not because of that valve. Liquid is relatively incompressible, so the more pressure you run the less volume the pumps will actually move. You may have issues trying to squeeze 700hp out of 255s at 58psi base on e85. Just a little forewarning. Aromic did a writeup on it if you'd like to reference that.
Old Sep 15, 2013 | 06:35 PM
  #25
The pressure mod is not a cure all, the Walbros still lose a lot of volume at higher pressures. But not allowing the pressure relief valve to open at 75 psi helps a lot.
Look at the following picture, notice how the slope changes drastically @ 75psi. A modded pump will not fall off as fast.
http://autoperformanceengineering.com/pics/255lph.jpg
So far I've got enough fuel, we will see how far it can take me. I run the GTO around 45lbs base so 65lbs under boost and it has plenty of fuel for over 1000hp at the flywheel.
I'll try to get some videos this week.
ARC
57
Feb 21, 2022 10:54 AM
thunder550
Oct 8, 2015 04:53 PM
Sexyrado327
Aug 2, 2015 04:08 PM
LoneSStar
Jul 27, 2015 09:27 PM
