RCSB Z71 / BW S372 / E85 / Thoughts on Power?
It should haul when I get all the kinks worked out. The best I have been was 11.91 on low boost and timing. That was the only full 1/4 mile run I have made without letting off. It has traction problems that will be hopefully fixed over the winter. I am in the process of making it a complete flex fuel vehicle, then I can turn up the boost and shoot for good numbers.
One of the reasons the Walbros suck for high pressure is that they have a relief valve that opens at 75psi. Making this valve inoperable helps a lot with the fuel flow falling off. They still aren't as good as some of the other pumps out there, but it helps.
