Radix or Whipple?
Old Nov 19, 2009 | 02:10 AM
AndysC3's Avatar
Default Radix or Whipple?
Hello, Im doing some research on which supercharger Im going to go with. My goal is to be around 550-600 RWHP. So far I have full exhaust, Will be swaping heads to Patriot Performance CNC stade III Ported heads, The TR blower cam. 214/230 .601/.579 117LSA. Just wondering which supercharger would work better for me. Thanks
Andy
Old Nov 19, 2009 | 06:54 AM
waterdog's Avatar
Whipple has a good head unit, everything else is better on the radix, fuel system, intercooler... My whipple with the piggyback fuel system never worked that well. It made good boost but the power wasnt there.
Old Nov 19, 2009 | 07:05 AM
Onetogofast's Avatar
NOTTTTTTTTTT Whipple, that is all.
Old Nov 19, 2009 | 07:37 AM
AndysC3's Avatar
is my goal of 600 rwhp doable? I will also be adding the snow preformance 2 stage meth kit to keep the aits down a bit.
Old Nov 19, 2009 | 08:05 AM
trever1t's Avatar
2nd fastest 5.3 ECSB
If you look around you'll see there are a lot of FI trucks on this forum....and most of the SC setups are Magnuson powered, for good reason.
We do have users sucessfully running Whipple, KB, Procharger, etc but some might say your responses are going to be a little biased
I make 575hp boost only with a 5.3. 600 from a 6L and the right supporting mods, possible I'd say.
Old Nov 19, 2009 | 10:14 AM
Bromaguire's Avatar
I'd go with a whipple. Once you get everything sorted you will have a better blower setup than with a maggie.
I am making 395whp and 424trq on mustang dyno with a 5200 redline at 10psi. That equals about 445-450whp and 500trq on a dynojet. I am redlining at 5200 because I am maxing my fuel system out. I'm getting a new fuel pump and bigger injectors and I would expect another 5-10hp and trq with just giving it more fuel. I am running marine 44lb injectors, custom tune, and a kenne belle boostapump right now.I got rid of all the whipple electronics and their two auxiliary injectors. The only other supporting power mods I have are jba shorty headers and a corsa exhaust.
I have plans of building my engine to a 408 this summer and 550whp on the mustang dyno should be no problem. I don't think I will even need to raise the boost to much more than 15psi.
The maggie is less efficent at higher boost levels so I don't think that it would be an optimal choice.
Old Nov 19, 2009 | 10:18 AM
trever1t's Avatar
I beg to differ. Blower only I ran 11.81 in the quarter with a little 5.3L
Old Nov 19, 2009 | 10:24 AM
TX Tahoe Z71's Avatar
I would go with a Radix... but I am biased.
There are also a lot more people on PT with them than with Whipples, so when you have questions/run into problems, there are going to be alot more people with experience who can help you out
Old Nov 19, 2009 | 11:13 AM
CharlyNali6.2's Avatar
Procharger!!!!!!!!
Old Nov 19, 2009 | 11:22 AM
Bromaguire's Avatar
You beg to differ what?
LOL I wouldn't make a decsion just because all the other kids at school are doing it. I would do my own research.
I am pretty sure the maggie will max out before the whipple correct and the whipple is more efficient at higher boost levels.
I have never had one issue related to my whipple. I don't have slip problems or anything. There are plenty of knowledgeable whipple guys on here also. I do see a lot of guys running into trouble with the maggies though.
