Radix Questions
Originally Posted by Dub Silverado
The pulley I have now is 3.3.
You think a 3.0 is safe along with a dyno tune? What should i see from that 8-9 lbs?
Yea, ill be getting a good tune so im not worried about that. I am working out all the bugs right now from the system then once im sure its ok im going to swap pulleys and get the tune.
welcome to the boost club. Say goodbye to your money, friends, job, and spare time. I suggest you weld that pulley on somehow, otherwise here will be your thread topics in the upcoming months.....
1. How much rwhp will a x.xx pulley give me
2. Should i get a dyno tune?
3. I layed down xxxrwhp!! time for a new pulley.
4. IAT's are a little high, Should i get a larger Xchanger for my intercooler?
5. Which meth injection do you guys run
6. WOW. IATs are way down now, time for a smaller pulley.
7. How much PSI can my stock bottem end handle?
8. I hear a rattling noise?!?
9. How much does a 408 long block cost?
10. new engine is in! How much boost can i run on this sucker?
I laughed so loud my wife came in the office. LOL. Every word is true however.
Cool, is that what the numbers represent in your sig? Do you have a crew or ex cab?
Radix, 3.0 pully, Nelson tune, stainless works long tubes, true dual 3" exhaust w/ high flow cats X pipe and two 18" mufflers, 180 t stat, msd wires, K&N FIPK, built 80e w/ 2800 stall. It was getting about 7.5-8 #s of boost.
The track times were on the stock 20 inch goodyears so they arent that great.
I havent had any problems with the 3.0 pully other than belt slip and spinning my crank pully. You should be fine as long as you get a good tune for it.
Do you have a crew or an EX cab? I will be pinning my crank pulley as soon as I get the stuff.
I hope not to have much belt slip with the new 100mm idler pulleys but we will see.
it is an ex cab. i have the crank pinned and have the 100mm pullys and i am still getting belt slip. Oh and start saving for a new tranny, mine only lasted about a month after i swapped out the pully.
carid
Sep 10, 2015 09:07 AM
