Radix Questions
I finished my install of my radix today and got the gauges hooked up and everything. I have a few questions though.
First off, i hooked up fuel pressure right to the fuel rail and im getting 60psi there. Is that ok?
Second, when i try and start the truck up its doesnt start up the first time. I turn the key off and it will start then. Any ideas?
Which nipple am i supposed to hook to for boost? There is a nipple that sticks straight up from the manifold in the back and thats where im at now. It seems to be reading high though. At a stoplight i get 4 inches of vacuum, under cruise it goes to about ten and when i stomp on it, it shows 10lbs of boost? Seems awful high.
What boost should i be expecting? I have the Lq9, radix, 3.3 pulley it came with, and dynatech headers and cats connected to a corsa sport exhaust?
Congrats on the completeing the install.
I believe 60lbs is good.
Did you remember the lil black 0 ring in the FPR that you take out of you're original equipment?
Im not sure where to hook it but that is way high.
I would think 5-6 lbs.
Originally Posted by Dub Silverado
Can you be more specific on the o ring you mentioned?
Ok, i got one thing fixed. It looks like I didnt hook the PCV from the valve cover to the back of the blower. The blower had a cap on it still though. I changed that around now im getting like 15-20 vacuum and about 5lbs of boost at wot.
