How much timing should I have....
Old Aug 17, 2006 | 06:28 AM
Allgonoshow's Avatar
Question How much timing should I have....
ran the truck with a scanner and showed 14 degrees at wot, o kr
1-2 kr on light throttle on incline, lot's of timing when just cruising at steady speeds.
Is 14 wot ok or should it be higher. 80 degrees outside and 115 iat's.
stock 3.4 pulley and stock radix tune.
thanx
Old Aug 17, 2006 | 10:54 AM
Last Call's Avatar
TOTM: January 2007
That seems a little low. I was running 18 degrees with the 3.1 pulley on the 5.3 with no KR.
Old Aug 17, 2006 | 12:36 PM
that's what I thought
Old Aug 17, 2006 | 12:37 PM
Lord Aries's Avatar
I think mine runs at 17 with the same temps you described at 7.5lbs of boost... steady crusing is like 24-30 of timing...
Old Aug 17, 2006 | 12:40 PM
BlownChevy's Avatar
blownerator
25 Year Member
thanx
The stock Radix calibration is set up for 16* of timing out of the box (safe). Seeing 14* at WOT means that the IAT correction table was more than likely pulling the 2* if the IATs were 130ish at WOT. Sounds about normal to me, the PCM is doing its job.
Old Aug 17, 2006 | 12:51 PM
that makes sense, do the iat's seem alittle high for that ambient temp?
80 and 130 degrees
Blown, did you received the superchips and escalade fuel pump i returned to you,
thanx for your help on that too.
Old Aug 17, 2006 | 01:14 PM
BlownChevy's Avatar
blownerator
25 Year Member
80 and 130 degrees
got it, thanks..
130* under boost at WOT sounds normal to me.......
thunder550
Oct 8, 2015 04:53 PM
kr1s
Aug 24, 2015 05:34 PM
smokeshow
Aug 23, 2015 08:23 PM
therock
Aug 23, 2015 01:37 PM
