Radix Questions
Old Aug 6, 2006 | 09:45 PM
1SlowHoe's Avatar
Destroyer of Transmissions
Originally Posted by Dub Silverado
The pulley I have now is 3.3.
You think a 3.0 is safe along with a dyno tune? What should i see from that 8-9 lbs?
Sure it would be safe, with a good tune. Stock pistons etc, seem to hold up pretty well to anything under 10psi. Some actaully run 12psi on a stock engine but, maybe they dont mind breaking something. I think you'd see 8psi on a 3" pulley. I have a LQ4 with a 2.75", I only see 7psi but that because of my cam and LT's. You should stick with the 3.3" for awhile and enjoy it. Once the power starts to feel normal, then move down a pulley size or 2. Just make sure you have it tuned right then or else bad things could happen at WOT
Old Aug 6, 2006 | 09:46 PM
Dub Silverado's Avatar
Yea, ill be getting a good tune so im not worried about that. I am working out all the bugs right now from the system then once im sure its ok im going to swap pulleys and get the tune.
Old Aug 6, 2006 | 10:00 PM
Whippled 496's Avatar
welcome to the boost club. Say goodbye to your money, friends, job, and spare time. I suggest you weld that pulley on somehow, otherwise here will be your thread topics in the upcoming months.....
1. How much rwhp will a x.xx pulley give me
2. Should i get a dyno tune?
3. I layed down xxxrwhp!! time for a new pulley.
4. IAT's are a little high, Should i get a larger Xchanger for my intercooler?
5. Which meth injection do you guys run
6. WOW. IATs are way down now, time for a smaller pulley.
7. How much PSI can my stock bottem end handle?
8. I hear a rattling noise?!?
9. How much does a 408 long block cost?
10. new engine is in! How much boost can i run on this sucker?
Old Aug 6, 2006 | 10:03 PM
Funny thing is that I already have a 3.0 pulley waiting, i am trying to decide between two tuners locally, i was curious about meth, and already am looking for a larger intercooler. The 4l80e is my next big project then the 408. You read my mind....
Old Aug 6, 2006 | 10:14 PM
1SlowHoe's Avatar
I laughed so loud my wife came in the office. LOL. Every word is true however.
Old Aug 7, 2006 | 12:17 AM
kbracing96's Avatar
ROFLMAO So,So, true...
Old Aug 7, 2006 | 01:12 AM
04Denali's Avatar
I have a 3.0 pulley and am seeing 7.5 pounds
Old Aug 11, 2006 | 08:05 PM
thunderwagen's Avatar
Cool, is that what the numbers represent in your sig? Do you have a crew or ex cab?
My mods when I did that pull were,
Radix, 3.0 pully, Nelson tune, stainless works long tubes, true dual 3" exhaust w/ high flow cats X pipe and two 18" mufflers, 180 t stat, msd wires, K&N FIPK, built 80e w/ 2800 stall. It was getting about 7.5-8 #s of boost.
The track times were on the stock 20 inch goodyears so they arent that great.
I havent had any problems with the 3.0 pully other than belt slip and spinning my crank pully. You should be fine as long as you get a good tune for it.
Old Aug 11, 2006 | 08:08 PM
Do you have a crew or an EX cab? I will be pinning my crank pulley as soon as I get the stuff.
I hope not to have much belt slip with the new 100mm idler pulleys but we will see.
Old Aug 16, 2006 | 03:52 PM
it is an ex cab. i have the crank pinned and have the 100mm pullys and i am still getting belt slip. Oh and start saving for a new tranny, mine only lasted about a month after i swapped out the pully.
JordanH
Dec 25, 2015 08:32 AM
projectnightcrawler
Sep 30, 2015 10:49 PM
spooneralmighty
Sep 11, 2015 02:28 PM
chevstang421
Sep 10, 2015 09:16 AM
carid
Sep 10, 2015 09:07 AM
