Radix Questions
Old Aug 6, 2006 | 01:20 PM
Dub Silverado's Avatar
Default Radix Questions
I finished my install of my radix today and got the gauges hooked up and everything. I have a few questions though.
First off, i hooked up fuel pressure right to the fuel rail and im getting 60psi there. Is that ok?
Second, when i try and start the truck up its doesnt start up the first time. I turn the key off and it will start then. Any ideas?
Which nipple am i supposed to hook to for boost? There is a nipple that sticks straight up from the manifold in the back and thats where im at now. It seems to be reading high though. At a stoplight i get 4 inches of vacuum, under cruise it goes to about ten and when i stomp on it, it shows 10lbs of boost? Seems awful high.
What boost should i be expecting? I have the Lq9, radix, 3.3 pulley it came with, and dynatech headers and cats connected to a corsa sport exhaust?
Old Aug 6, 2006 | 03:54 PM
Breeze's Avatar
11 Second Truck Club
Congrats on the completeing the install.
I believe 60lbs is good.
Did you remember the lil black 0 ring in the FPR that you take out of you're original equipment?
Im not sure where to hook it but that is way high.
I would think 5-6 lbs.
Old Aug 6, 2006 | 04:02 PM
Can you be more specific on the o ring you mentioned?
Old Aug 6, 2006 | 04:13 PM
moregrip's Avatar
what a rush!
Dub, do a search using fpr, or fuel pressure regulator, you should get some hits that will help you out
Old Aug 6, 2006 | 04:16 PM
Im re-reading the instructions and it only says to do the FPR step if you have a 2003 truck. Mine is a 2006 so i skipped that step. Any thoughts?
Old Aug 6, 2006 | 04:36 PM
Ok, i got one thing fixed. It looks like I didnt hook the PCV from the valve cover to the back of the blower. The blower had a cap on it still though. I changed that around now im getting like 15-20 vacuum and about 5lbs of boost at wot.
Old Aug 6, 2006 | 07:12 PM
thunderwagen's Avatar
Mine came with the same pully and i saw 5-6# with that set up. my fuel pressure reads 68 at idle and drops to 64 at wot.
Old Aug 6, 2006 | 07:47 PM
Cool, is that what the numbers represent in your sig? Do you have a crew or ex cab?
Old Aug 6, 2006 | 08:16 PM
1SlowHoe's Avatar
Destroyer of Transmissions
That sounds exactly right.
Have fun
Old Aug 6, 2006 | 08:54 PM
The pulley I have now is 3.3.
You think a 3.0 is safe along with a dyno tune? What should i see from that 8-9 lbs?
