Radix pulley bolt torque and locktite?
Already did it, just went as tight as I could until the strap wrench would slip. Figured if I could hit it with a torque wrench, I would feel better.
BTW How did you pull the factory one off? I had to use a 3 jaw puller. It's the only thing I could think of. Is that the right tool?
Also the used pulley I bought had circular scratches on the back around the hole, like it was rubbing the housing. Ever heard of this?
If you don't do this chances are you will spin the balancer.
Correct torque sequence as far as I know it.
Get balancer back on.
With OLD bolt torque to 240 lb/ft - This assures balancer is fully seated.
Remove old bolt - Install new bolt and torque to 37 lb/ft
Then torque 140 more degrees of rotation
ive never heard of a pulley rubbing the housing...if it isnt doing it now on yours id assume youre fine.
zblee
63
Jun 10, 2023 01:25 PM
