radix intake gasket whoopsie
Old Sep 25, 2008 | 06:50 PM
PSM's Avatar
PSM
Default radix intake gasket whoopsie
When grinding the tabs off a new set of intake manifold gaskets i knicked part of the gasket. here are some pics... can i put a bit of some sort of rtv on this.. or should i just leave it alone... or get another new set
These pics are all the same spot.. different angle pics
Old Sep 25, 2008 | 06:59 PM
thunder550's Avatar
High on diesel fumes
Hmmmm.....personally I'd probably try to run it, looks like it would seal up once you got the manifold tightened down and squished the gasket in there.
Old Sep 25, 2008 | 07:00 PM
Stoichiometric's Avatar
+1. That's not too bad.
Old Sep 25, 2008 | 07:08 PM
kbracing96's Avatar
+2 I run it. If it makes you feel better, you could put a SMALL dab of silicone on it.
Old Sep 25, 2008 | 10:32 PM
Y2KLimited's Avatar
I'd go with it as well....
Old Sep 25, 2008 | 10:39 PM
BlownChevy's Avatar
blownerator
25 Year Member
I would not use it. If you have any issues, tearing the blower off and replacing the gaskets will be more of a pain in the *** than the gaskets are worth. Just my .02
Old Sep 25, 2008 | 11:07 PM
PSM's Avatar
PSM
and i was all set because it was unanimous until you lol.... $100 bucks now , or lots more time and $100 bucks later
Old Sep 25, 2008 | 11:09 PM
BlownChevy's Avatar
blownerator
25 Year Member
check on the felpro part...save you about 45 bucks
Old Sep 25, 2008 | 11:11 PM
trever1t's Avatar
2nd fastest 5.3 ECSB
I would take the $100 now route because it could end up being $1257 later
Old Sep 25, 2008 | 11:14 PM
I have used gaskets where the rubber was so flat it didn't stick up past the plastic w/out leaks. I wouldn't recommend this but it is a true story.
I forgot how expensive those are.
