Radix guys with boost gauges help.
Old Jun 30, 2006 | 12:18 PM
j.whitten's Avatar
Default Radix guys with boost gauges help.
I bought a mechanical boost gauge( a cheap one) and it says splics into a vaccum line on the intake, where are you tapping into?
Old Jun 30, 2006 | 01:23 PM
04Denali's Avatar
There is a nipple in the back of the SC right buy a brass fitting, you can tap into there (drivers side)
Old Jun 30, 2006 | 01:51 PM
Just find a small vaccuum line tee and splice into the line going to the bypass vaccuum line.Simple easy and effective.
Old Jun 30, 2006 | 01:54 PM
BlownChevy's Avatar
blownerator
25 Year Member
The only reason I would not reccomend that is if that tee fails, that actuator will not work.
There is a 1/8 nipple in the back of the intake manifold that will work best for you.
Old Jun 30, 2006 | 02:13 PM
j.whitten's Avatar
Okay I think I found the nipple, can I also use the plug instead of the nipple? Also those of you that have electric fans where are you mounting your intercooler tank? Mine was on the shroud but I am in the process of putting dual 16" fans on found out they both won't fit on one side so I have 1 pushed and 1 puller that cover pretty much the entire radiator.
Old Jul 1, 2006 | 09:37 AM
04Denali's Avatar
Mine is conected to the fuse box on drivers side before the battery
Old Jul 1, 2006 | 10:36 AM
Bill Reid's Avatar
Read through the manual on the installation of a Radix system for trucks factory equipped with e-fans and you get an idea of how/where to mount the tank. Maybe even call Magnuson and get the mounting bracket...
http://www.magnacharger.com/pdf/manu...00-2003-06.pdf
Bill
Old Jul 1, 2006 | 12:37 PM
BlownChevy's Avatar
blownerator
25 Year Member
I think I have a mounting bracket at the shop. PM me and I will check.
Old Jul 1, 2006 | 10:23 PM
JimS's Avatar
I put a T in the line that runs from the fuel pressure regulator to the back of the Radix. Is that acceptable?
chopperloco
Jul 10, 2016 10:45 PM
BKnBLK05
Dec 28, 2015 08:52 PM
thunder550
Oct 8, 2015 04:53 PM
Go5.3tt06
Sep 12, 2015 09:29 AM
lxcoupe
Jul 21, 2015 02:12 AM
