Radix and 408 low fuel pressure help
Old Feb 13, 2013 | 02:00 PM
Q8 6.0's Avatar
Default Radix and 408 low fuel pressure help
I have 2005 sierra I have in the tank fuel pump from magnacharger I have noticed after 408 install my pickup is always around 51 psi at idle and at full throttle it is around 45 psi. Anyone have tips.how to increase the fuel pressure all round
Thanks
Old Feb 13, 2013 | 02:06 PM
Q8 6.0's Avatar
https://www.performancetrucks.net/fo...1&d=1360785811
Old Feb 13, 2013 | 04:18 PM
nonnieselman's Avatar
You might try to get a Adjustable Regulator? Do away with the factory and just use it with a vacuum/boost reference maybe?
Old Feb 13, 2013 | 05:51 PM
Q8 6.0's Avatar
That sounds very complicated but thanks for a idea I was looking to try simple solution first to check maybe lines or electric... Dose anyone think the fuel pump which came with the radix kit is enough for the 60lb injectors 10psi boost and 408
Thanks
Old Feb 13, 2013 | 09:26 PM
Gadgetized's Avatar
If you are running 10 PSI on a 408 with a Radix, you are really turning it! You could try a boost a pump or a Magnavolt to increase the fuel flow. The real problem is that the regulator is in the tank. The regulator sets the fuel pump inside the tank, and the engine runs off of the fuel pressure at the rail. In a perfect world it would be the same, but the lines and distance cause a restriction lowering the pressure at the rail.
Old Feb 14, 2013 | 06:39 AM
Q8 6.0's Avatar
I think I understand what your saying. Is that the regulator is commanding for example 55psi but the travel and size of pipes fuel rail pressure will be lower yes makes perfect sense.. So my fuel pump and regulator are working perfectly at idle as I see about 51 psi at rail. But when I go full throttle pump can't keep up around 5000 rpm so looks like boost pump might help..
Went to dyno last night air fuel just gos lean around 5000 rpm
<a href="http://s150.photobucket.com/albums/s108/SRTEE/?action=view&current=8610af940db214cedf03cded75d1f 58a.jpg" target="_blank"><img src="http://i150.photobucket.com/albums/s108/SRTEE/8610af940db214cedf03cded75d1f58a.jpg" border="0" alt="Photobucket Pictures, Images and Photos" /></a>
Old Feb 14, 2013 | 06:40 AM
Q8 6.0's Avatar
Old Feb 14, 2013 | 08:04 AM
8 Second Club
You need more pump or a boost a pump.
Old Feb 14, 2013 | 09:40 AM
Q8 6.0's Avatar
Yes bro .. That what im going to do first i going tonight get msd boost a pump i will do a serch on this fantastic forum how to install it will go back to dyno see if it works
But im worried that on dyno with zero g force pull it wont give real world air fuel pressure
Old Feb 14, 2013 | 10:41 AM
TX Tahoe Z71's Avatar
When installing my BAP on my 2003 Tahoe, it was the thick gray wire under the underhood fuse box. Mounted the BAP with self-tapping screws on the backside of the fuse box facing the firewall. With the stock flex fuel pump, it's keeping up with my 75# injectors.
