Question for Those Turbo Trucks
Old Jan 5, 2006 | 10:20 AM
  #31
Mort's Avatar
Cool
Originally Posted by NoChrome
Im pretty brave, that translates into old enough to know better and too young too care. What Im really talking about is how much boost can the motor take with a big intercooler, and no meth/alky.
That is probably a hard question to answer with a high degree of certainty. There are too many variables such as driving style, PCM tune, etc. I have my high boost setting at about 10 PSI ( seems closer to 9 PSI in the colder weather ) but generally drive around on my low boost setting of 5 PSI. I have meth injection but no IC. I generally data log when I am on the high boost setting just to keep and eye on things and I am pretty sure that it is safe. Can the engine take it in the long run? I am not sure but generally I use the low boost setting and don't beat on it all the time so I am sure it will last a long time. Keep an eye on your gauges because things can go wrong in a hurry when you are running high boost levels.
Old Jan 5, 2006 | 10:45 AM
  #32
Mort's Avatar
Cool
Originally Posted by nochance
About driving in the snow and rain since the turbo is under the truck and exposed to pretty much everything, Has anybody had any problems with water being sucked up or anything of the sort? Thanks alot you guys are really helping me out.........
Being aware of the risk should help you avoid any problems associated with it.
I drive with mine in snow and rain and have not had any problems. I have never even put the sock on the filter. If you are worried put the remote filter mount kit on in the winter or during the rainy/flood season. My filter gets rain and snow on it between the cab and box but it does not seem to hurt anything. The filter gets a little water on it in the rain but unless you have an IC there does not seem to be anywhere for it to build up and cause a problem. In small amounts it seems to get pulled through and injested much like it would using meth injection. I just keep an eye out for deep water and try to avoid deep puddles as much as possible. It is worth taking precautions because a hydraulic locked engine is no fun. So yes there is some risk to the filter drawing in water but a little common sense will go a long way to preventing any problems but not in negating them all together..
Old Jan 5, 2006 | 04:20 PM
  #33
NoChrome's Avatar
I dont beat on it too often but when I do its normally pretty bad. Thanks for the input, Im just trying to learn as much as I can right now. Really trying to decide between a radix and turbo. But Im no where close to buying one, or even deciding for that matter.
Old Jan 6, 2006 | 12:53 PM
  #34
nochance's Avatar
Thanks....Thant helps out alot I think I am going to still do custom kit
ferrellrooster
Mar 6, 2025 03:22 PM
5.3lSilverado
25
Aug 29, 2016 12:48 AM
kyle's v
Oct 4, 2015 12:37 PM
Austino
Jul 30, 2015 03:28 PM
black6spdz
Jul 16, 2015 01:32 AM
