the procharger thread
Old Jul 31, 2012 | 05:44 PM
  #81
AndysC3's Avatar
Originally Posted by Phantomx55
K, thanks guys. Picked up a set of TR6 plugs today and getting the gauges in finally. Hopefully this gets me running better...been dying to finally get to the track for some new times.
EDIT: Shop did a smoke test and found the bypass valve is leaking badly. It's the shitty looking one that came with the kit and was wondering which bypass valve I should replace it with...There shows 2 separate types on the website, open and closed and if I should go with the bullet or race valve.
Yes, the stock bypass valve is very inefficient. Either bypass from procharger would be beneficial. I will end up with the big open race valve eventually.
Old Jul 31, 2012 | 06:11 PM
  #82
Mangled03gmc's Avatar
Baltimore Whore
The vortech race valve is a very nice unit, is more then half the price of the big red. This is before I had the bigger blower, but it does seem even louder now( maybe blowing off more air)
Old Jul 31, 2012 | 06:16 PM
  #83
AndysC3's Avatar
Hmm, I like that.
Old Jul 31, 2012 | 08:45 PM
  #84
Phantomx55's Avatar
Well had the gauges put in today, and not seeing any Boost whatsoever...wasn't exceeding 3500 rpms, but I think I should be seeing something at that point...Stays deep in vacuum except for one quick burst to about 4k rpms where it just barely touched boost before I let off as it started with the check engine..
Took the bypass valve off to check it and just putting some air through it from my lungs I can feel it coming out the other end and side..would this be my culprit? Here's a picture of it:
Old Jul 31, 2012 | 09:54 PM
  #85
AndysC3's Avatar
mine doesn't start building boost until about 3600rpm. And I have a D1 with a 4" pulley. are you putting it in Neutral and revving it?
Old Jul 31, 2012 | 10:35 PM
  #86
Mortiz's Avatar
Formerly PurplePearl (2014-04-06)
You guys dd these? How do you like it?
Old Jul 31, 2012 | 10:42 PM
  #87
Phantomx55's Avatar
Hmm..thought it started building boost lower than that...It was while driving and was staying very light on the throttle though. Ordered a normal proflo anyway to replace the one I have.
Old Jul 31, 2012 | 11:21 PM
  #88
AndysC3's Avatar
this is one of my logs. on the far left of the graph you can see the rpms are about 3600. if you look to the right side the KPA is 92. Atmosphere is about 90 here.
Old Aug 1, 2012 | 07:17 PM
  #89
Phantomx55's Avatar
Edit: It's fixed, 12.503 @ 105
File Type: efi
Old Aug 20, 2012 | 07:03 PM
  #90
ak2007r6's Avatar
Originally Posted by ak2007r6
2011 CCSB 6.2
D1SC
4.38"
3 core intercooler
65lb Fast Injectors
Stock Transmission
Stock CAM
Stock Stall
Seeing 12lbs on the 1-2 shift and around 10 after that at WOT
No track times yet
Guess I could update mine since it's changed quite a bit.
2011 CCSB 6.2
D1SC
4.38"
3 core intercooler
Custom Forged Pistons
Injector Dynamic ID850 Injectors
1.8 Yellow Terra Roller Rockers
ARP Pro Series Head Stud Kit
Valve springs / push rods / hardened locks
Custom Speced Cam by Pat G 218/234 .596/.610 117 LSA +3
Circle D billet 258mm multi-disc 2C
Tru Cool 40k
New track times coming soon.
