procharger intercooler questions...
Old Sep 5, 2007 | 08:17 PM
phasemaster1's Avatar
Default procharger intercooler questions...
1. Which one are you using procharger one or aftermarket one? ( # core's and dimensions)
2. mounting ? flat with air dam, upright modified bumper...
Old Sep 5, 2007 | 11:14 PM
WJ MARK's Avatar
I used the procharger one when I had mine, mounted flat with air dam. It seemed to work fine.
Old Sep 6, 2007 | 08:07 AM
blown3qtr's Avatar
procharger 2 core flat w/ air dam.
Old Sep 6, 2007 | 08:09 AM
Bad_Apple's Avatar
I've always ran a 2-Core flat with air dam. When I get my truck bacl together I'm going to run a 3-Core Flat with air dam.
Old Sep 6, 2007 | 10:21 AM
02BlueStepside's Avatar
2 core flat with air dam for now. I will go a little bigger one day, but not sure if I will stay flat or go upright.
Old Sep 6, 2007 | 05:04 PM
Blown06's Avatar
8 Second Truck Club
I run the 3-core, flat with air damn. Going to a front mount soon though.
Old Sep 6, 2007 | 07:17 PM
Rick_Vor's Avatar
FMIC 24x12x4. Had to notch the frame rails. Air Inlet Temps run 8-12 degrees over ambient during normal drivng. Hits up to 20 degrees over ambient after a full run but then goes right back down. I feel there is a slight amount of lag with such a large FMIC. The benefit may be that boost stays higher during shifts but I've never ran a stock Procharger intercooler to compare. I run 10lbs of boost with a stock LQ9.
Rick
Old Sep 7, 2007 | 11:02 PM
Superado's Avatar
11 Second Truck Club
ran 2-core ProCharger, flat with air dam for several years...now running e-bay biggun...
tilted slightly...scoop coming soon if I decide not to stand it up...
Old Sep 8, 2007 | 09:25 PM
Thanks for everyones input so many different ways to go about this I just got hooked up with a d1sc head unit and brackets. Just need to put everything else together. toughest thing seem to be 60# injector tuning watching a few people trying to tune and going very slow.
$A_Money$81
Mar 27, 2023 10:25 AM
madmann26
Apr 29, 2020 09:17 AM
turbo6c3
Oct 5, 2015 06:11 PM
old motorhead
Sep 29, 2015 08:22 PM
murderedSS
Sep 27, 2015 10:16 PM
