procharger install help!
Old Jan 19, 2012 | 08:24 PM
burdman864's Avatar
Default procharger install help!
Hey guys just got a pcs1 for my stock 2007 1500 gmc classic. Going to try to save some money and install it myself, and was wondering if there was anything I should look out for as this is my first install! Also its not flex fuel and people tell me in need bigger injectors sooo what size would be best? My goel is not to make it a project truck but just have a little fun. All info. would be great because I know little.
Old Jan 19, 2012 | 08:27 PM
08cheyennesc's Avatar
60# injectors ,so you have room too grow later.
Install is very simple just time consuming.
Mangled03gmc's Avatar
Baltimore Whore
What IC, 2 core that mounts under it or a front mount? 44' lb injectors, a computer reflash is a good idea, almost a must.. If it is a complete kit it is pretty much strait forward.. If you have a decent mechanical ability it should be a easy install. Takes some time and patience..
Old Jan 20, 2012 | 06:30 AM
burdman864's Avatar
It is the 2core under mount and I plan on getting it tuned if thats what you mean by computer reflash? How hard is it to upgrade to e85 or should I just put bigger injectors and fuel pump in? With stock trans. and engine what would be a safe psi. to run? Also what do you think my hp will be?
Old Jan 20, 2012 | 08:14 AM
sureshot's Avatar
It's a pretty straight forward install. Bolt the bracket and head unit on, bolt the intercooler on, and then it's just a matter of routing the piping. As stated before, go with 60# injectors and a bigger fuel pump. A tune is a must, no exceptions. Definitely get a wideband gauge to monitor AFR's as well. You'll be on borrowed time with a stock tranny with any boost level.
Old Jan 20, 2012 | 08:22 AM
Baltimore Whore
Do the bigger injectors IMO.. The stock trans at a minimum needs a shift kit, servo.. On 8 lbs a good tune I don't see why it shouldn't make 425 hp on 8 lbs
Old Jan 20, 2012 | 06:26 PM
burdman864's Avatar
Thanks for all the info.
Old Jan 20, 2012 | 06:59 PM
Check out this page,it's an NNBS but it's almost the same as an NBS,should give you an idea about the install
2008 Chevy Silverado ProCharger Supercharger Installation - Custom Chevy Truck - Truckin' Magazine
LCHEE
Oct 24, 2020 04:10 PM
D1SCSS
Jan 25, 2016 10:14 PM
echoman
Aug 22, 2015 01:53 PM
zblee
Aug 3, 2015 03:45 AM
fcompean
Jul 15, 2015 09:55 PM
