procharger help
Old Dec 8, 2009 | 11:08 PM
Trezent's Avatar
Angry procharger help
hey everyone i did a search and found nothing so here i go.
just recently bought a used procharger with three pullies. i got the small one off but i am having the damnedest time getting the other one off.
you guys got any tricks on getting them ***** on. just cant i am affraid i am going to mare the pulley and ruin it.
please help.
Old Dec 9, 2009 | 01:22 AM
Rick_Vor's Avatar
The safest way is to use a 3 jaw puller. Back the bolt out a few turns and then use the puller to slide it off till it hits the bolt. Repeat until it pulls off by hand. The 2nd option if it's not too tight is to use a small piece of 1/2" x 1" wood stock against the pulley and a small pry bar. Put the wood against the pulley, give it a nice pry with the pry bar, rotate the pulley and repeat. Slowly work your way around the pulley till it finally comes off.
If your having trouble braking loose the locking bolt, grip the pulley with a belt wrench and then loosen the bolt with the appropriate socket. Some people use channel locks to grip the pulley but it will mar the pulley.
Rick
Old Dec 9, 2009 | 12:20 PM
Trezent's Avatar
Rick
Man i really apreciate the help but i got it off used the hot cold method. came out pretty easily but i can get it "Back ON" that is the problem but like i said thanx for the input.
Old Dec 9, 2009 | 12:52 PM
Rick_Vor's Avatar
Back on is the easy part. Just tighten the bolt!
Rick
madmann26
Apr 29, 2020 09:17 AM
murderedSS
Sep 27, 2015 10:16 PM
MOBBN
Sep 22, 2015 08:07 PM
murderedSS
Sep 22, 2015 03:53 AM
Justin87gn
Sep 10, 2015 12:06 PM
