fuel tank????
Old Dec 9, 2009 | 08:59 AM
05crew's Avatar
Default fuel tank????
i have been talking to trick about a new fuel tank, and i should be hearing back from him soon on a price.. he had said that i could just put a bulkhead fitting in my stock tank and let the pump feed from there.. now the ? is has anyone done this. if so where did you put it..Should it go in the back of the tank at the rear of the truck aboud an 1" or so off the bottom? or the front of the tank? was thinking that if it was at the front of the tank then if might suck a little air on a low tank. but i dont run it that low anyway. and if i do its just driving around or on an open road.
so if that is the case i should be able to put he fitting in and just block of the on on the pick up tube...the sending unit would be the same and the return would still go in the top of the tank like it is now in to the bucket....
let me know what yall think....o and i pick up the motor and its in the truck should finsh it up tonight or so.....ill have some pic up soon...
Old Dec 9, 2009 | 11:19 AM
LsxCody's Avatar
im not sure about your tank situation,but what did u decide on turbo and motor?
Old Dec 9, 2009 | 01:29 PM
05crew's Avatar
the same 88mm is going on..if someone was to buy it i would go to a 91 but for now i just want to drive the damn thing.....u going to the meet this weekend? i cant make it on sat but im trying to go sunday morning....???
Old Dec 9, 2009 | 04:35 PM
MikeGyver's Avatar
Originally Posted by 05crew
.. he had said that i could just put a bulkhead fitting in my stock tank and let the pump feed from there.. now the ? is has anyone done this. if so where did you put it..Should it go in the...
I saw some pictures awhile back of a guy that put one in the bottom of the tank towards the back. Oh, yeah, it was me:
https://www.performancetrucks.net/fo...d.php?t=440857
It's feeding a pump that only runs when there's boost, so the fitting will always be submerged because when the fuel sloshes forward when I let off of the gas, the pump will be off.
Old Dec 9, 2009 | 05:41 PM
LsxCody's Avatar
Hey Josh pm me ur number. Hopefully ill have the bugs worked out of my truck before the weekend
ss454327
Oct 17, 2015 03:43 PM
cosb
Aug 24, 2015 09:08 PM
Sevex
Aug 22, 2015 12:12 AM
ss4chad
Aug 15, 2015 02:25 AM
