Procharger Advice
Old Jun 20, 2015 | 08:34 AM
  #31
George C....'s Avatar
Formerly ScreamingL
Originally Posted by Blown06
I find it real hard to believe a real 540 to the tire from a 5.3 with a p1sc at 12 psi................not to mention those big *** tires.
George.......you fo real?
very simple, blower is over spun...where most blowers peak boost at RPM i peak boost then drop boost
it has TFS as cast 220s, a 218/218 570/570 112 cam, 1.75 headers, 2.5" y pipe into a 4" merge, 4" exhaust thru 4 mufflers
its on a LC9 5.3 and with ls9 gaskets compression is around 10.3
18* timing on a single m10 nozzle made 539.xx
i drive truck on 12* with no meth which is around 495 rwhp
truck at time had the 10bolt with 342s, swapping the 35s for stock size wheels and tires only saw a difference of 10 rwhp
im actually upset with the power as typically with 12psi from what stuff ive built over the yrs with a turbo makes far more power
the p1sc has a 3.2 pulley on it
Old Jun 20, 2015 | 02:10 PM
  #32
Wrecker 426's Avatar
BLWN Z71 hit the 500 rwhp club - YouTube
sorry for thread jacking again
thanks i hope to get somewhere around there, got a bigger cam and gears but i don't have those heads or CR. Is that with a 60E or 80E?
Old Jun 20, 2015 | 02:37 PM
  #33
Formerly ScreamingL
first bigger cam doesn't always mean more power
Second i have neither of those trans you mentioned ...I have a 6l80
3rd my compression isn't much higher then stock....it's 0.3 more then stock was
Truck now has 4.88s, which was done for towing
Old Jun 20, 2015 | 03:16 PM
  #34
cam-tracking, 6l80e still has more rotating mass then the 60 version, thats why i was curious, my cr on my truck is more like 9.5, first year 5.3 problems
Old Jun 20, 2015 | 04:19 PM
  #35
Formerly ScreamingL
Correct lm7 are 9.5cr
Also might as well add a lc9 comes with the better intake manifold
madmann26
Apr 29, 2020 09:17 AM
bearden86
26
Nov 15, 2015 03:58 PM
blackedoutchevy22
Oct 1, 2015 08:07 PM
Chevy305
Sep 28, 2015 09:21 PM
murderedSS
Sep 27, 2015 10:16 PM
