Procharger Advice
Old Jun 12, 2015 | 12:22 PM
bgray's Avatar
TOTM: June 2007
aaa I see. I had Maf location mixed up in my mind. I see the procharger MAF location is a on the inlet pipe about 1.5 feet away from the TB. So i should be good to go if I mount the valve just off the Charger
Old Jun 12, 2015 | 03:06 PM
bgray's Avatar
TOTM: June 2007
Bob @Brutespeed has been helping me big time. Looking at the Black D-1sc, gave me an awesome deal on the whoile setup w/upgrades and injectors
Old Jun 13, 2015 | 11:39 AM
02_Orange_D1SC's Avatar
Fastest D1 Procharged Truck
with the higher compression your truck has it should run really good you better do a meth injection kit it will help big time
Old Jun 14, 2015 | 09:37 AM
bgray's Avatar
TOTM: June 2007
What are you referring to it helping? Power, longevity?. Consider Imma shoot of 6-8 psi, closer to 6 psi tho
Old Jun 14, 2015 | 02:03 PM
you can run less boost and make good power and have it be snappy down low unlike cars with low compression which are doggy down low until boost kicks in
Old Jun 15, 2015 | 07:26 AM
bgray's Avatar
TOTM: June 2007
Thanks for the advice, what Meth kits seem to be the favorite around these parts?
Old Jun 15, 2015 | 08:42 AM
George C....'s Avatar
Formerly ScreamingL
I've ran meth kits and ran without them
You truly have to ask yourself what are your true plans?
If every last bit of power then yes meth is required but meth isn't required if you aren't looking for every last power
Example my crewcab with the blower, it's 12Psi and I daily drive on 12* timing...make 500 rwhp and been doing so for last 15k miles
Now with I go to track I turn meth on and add in my other tune which has 18* timing
My motor is around 10.3cr
Old Jun 15, 2015 | 11:25 AM
bgray's Avatar
TOTM: June 2007
Its not the power, I dont track it, dyno it, or heck evne drive it much. Ive had the truck for years, literally everything has been massaged, and i figure a like procharger would be cool to add to the mix. Now i know some guys may give me **** for that, but ownership experiences are differnet for each person.
So no im not looking for the most power possible, Im more concerned with getting it on and keep it Safe as im 12:1cr(so ive been told)
Old Jun 15, 2015 | 09:37 PM
JordanH's Avatar
Restricted
After reading this... The P1-sc will be more than adequate for your needs. Spend the extra $400 on some nice gauges, locker, or something?
Old Jun 15, 2015 | 11:31 PM
Blown06's Avatar
8 Second Truck Club
While I don't run meth anymore...........I certainly attribute it's use in my old set up to its longevity and performance. Julio is the man at alkycontrol last I checked. I've heard his kit with another brand of nozzles make a great kit.
