PCV system for Turbo???
What are you turbo guys running for a PCV system, and how do you like it? I've heard that a filter on each valve cover, eliminating the PCV valve works just fine. I've also heard it doesn't, and that you need a catch-can for everything to work properly under boost. I'm up in the air on this one, opinions appreciated...
I'm running a catch can with a 1.0" hose that tees to both valve covers and no PCV. Seems to work well but you will need to adjust youe tune for it. A filter on each valve cover would do the same thing but it will make a mess from the blow-by after a hard run.
Mounted my catch can behind the passenger heads light with the hose running along the fender and across the firewall to the valve covers.
Rick
Rick
05GMC4.8
Aug 7, 2015 09:55 PM
FlowmasterMufflers
Jul 22, 2015 01:29 PM
