Out of injector?
Old Dec 14, 2009 | 12:03 PM
  #21
Okie5.3's Avatar
Appreciate all of the responses from you guys.
As far as the fuel pump goes, I have 255 in tank pump that is less than a year old as well as a FP gauge. Under boost pressure drops from 62-63psi to 58psi (normal).
Got your PM SRT10KLLR, appreciate it. I will get back with you within a fews weeks. Gotta get X-Mas out of the way.
I think I'm gonna go ahead and pull the 2.8 off and throw the 3.1 back on (5psi) and see what the IDC is with less boost. I'll try and do that tonight and post up what I see later tonight or tomorrow. It's supposed to be cold as hell again tonight, so conditions should be nearly identical as the log above.
Again I really appreciate the info guys.
Old Dec 14, 2009 | 03:10 PM
  #22
SRT10KLLR's Avatar
Former Vendor
Originally Posted by dewmanshu
as long as fuel pressure isn't dropping, you need to step up injectors. (the boost a pump will work but will incorporate another item that can fail. and plenty of people I know can confirm it DOES happen)
Even if you do have a clogged fuel filter(super rare) or bad pump, I still say that 6.0L and 2.8" pulley needs bigger than 42# injectors. Comparing a 5.3 to 6.0 on IDC is not fair, even with cam values. Hell the 5.3 can produce ~11#'s of boost with the 2.8" but the 6.0 can only produce ~8#'s. Just an example of the volume difference.
SRT what's the flow on those plug and play 60's at 60#'s? Just like the mototrons? You should link that thread discussion in your sig. LOL
Mine are 63.4 lb/hr at 3 bar(43.5 PSI) or 73.2 lb/hr at 4 bar(58 PSI) but vary a little. They are flow matched and come with a flow sheet.
Here is a link: https://www.performancetrucks.net/fo...=416134&page=2
$A_Money$81
Mar 27, 2023 10:25 AM
shootermwc
Oct 8, 2015 01:45 PM
KleanKustoms
Sep 30, 2015 05:07 PM
Wrecker 426
Sep 29, 2015 11:00 PM
sTNT971
Sep 26, 2015 04:22 PM
